 Post subject: 2TB WD erros in mods (006A,006F,0068,0069 and 0004 ).
PostPosted: February 15th, 2014, 4:26
Hi Friends
I have this problem with 2TB WD20EARS-00MVWB0 erros in mods (006A,006F,0068,0069 and 0004 ).
I cannot access the data anybody can help please thanks
 Post subject: Re: 2TB WD erros in mods (006A,006F,0068,0069 and 0004 ).
PostPosted: February 16th, 2014, 4:50
The drive is detect in the computer bios?
Is detect in device manager in windows?
P.S.
mod 6F results always with bad CRC also on good drives, it's normal...
My firmware database:
PostPosted: February 16th, 2014, 6:50
Did you try to read mods with sediv?
I had troubles reading mods on some WD drives with HD Doctor and WDR, but any problem with sediv.
Try with Sediv demo version, you can read ROM + mods (via ID or via ABA) and see if you still have those error:
http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
PostPosted: February 17th, 2014, 13:03
Bios detect the hdd.But cannot access the data.
I used SD ,detect 006A,006F,0068,0069 and 0004 errors.
PostPosted: February 17th, 2014, 15:48
Have you tried to clone it in DE or with some dos toos as DMDE or Mediatools?
If cloning works but very slow everywhere on surface, then very likely hdd has bad sectors + relo list problem.
You can clear relo list in HD Doctor by pressing 'slow repair':
viewtopic.php?t=27905&f=1&start=0#p191573
then you should been able to clone fast...
If it's not possible to begin cloning then most likely you have bad heads
PostPosted: May 23rd, 2014, 12:55
in 006F for most drives that module can be bad even in new drives so it doesn't matter
Users browsing this forum: No registered users and 51 guests
