 Post subject: Compact Flash with 2 partitions howto coppy ?
PostPosted: February 17th, 2014, 14:56
Hi everybody,
I need to copy more then 500 cf-cards. Managed to do it with HDD raw copy tool. But...
I'm looking to automate this job.
Is there a commandline interface to copy for ex. 2 partitions to a new cf-card?
This is how de cf-card is partitionned:
Partition ### Type Size Offset
Partition 1 Primary 11 MB 31 KB
Partition 0 Extended 992 MB 11 MB
Partition 0 Logical 992 MB 11 MB
DISKPART>
Does anyone know how to clone this disk in a way that can be automated.. ?
Thanks for the effort,
Regards,
 Post subject: Re: Compact Flash with 2 partitions howto coppy ?
PostPosted: February 17th, 2014, 18:09
You could use DD in Linux.
PostPosted: February 17th, 2014, 19:37
+1 for DD, and a bash script or whatever.
make sure you test the first ones, and also test if you have any different SD Cards, even slight differences.
I had issues with cloning/re-imaging cards that were slightly smaller than the original, as they are not all the same size, they are best described as approxiamately the same size.
PostPosted: February 18th, 2014, 11:22
Thanks for u reply's.
I'm a windows guy,.... is there a windows equivalent for dd ??
I have to dig into it otherwise, use a bootable linux.
w'll see.. .
PostPosted: February 18th, 2014, 17:26
funnily enough if you chuck "windows equivalent for dd " you do get some options ;)
I think I saw a dd for windows quite a while ago, so you may be lucky. But if you need to use a Linux boot CD I think it shouldn't be too bad to get it figured out. you can always post your challenges back here to get where you need.
good luck
Users browsing this forum: No registered users and 159 guests
