That's a great question; where are the errors located?
I turned to HD Tune, initially, but SMART health monitor wasn't functioning properly. I could see the data values, but it couldn't verify the disk's health. I had installed it on my company's loaner laptop. I don't know if it was the tool, the SSD having compatibility issues with some SMART tools, or maybe it's permissions since I don't have full admin rights. I've read that some SSDs, notably ones when they were first released, either had no support for SMART there inconsistent issues. My SSD does have support for SMART and TRIM, as it turns out, but I know TRIM support is disabled because the OS is WinXP. As far as SMART, I installed HD Tune Pro on my personal laptop and I had no issues whatsoever with SMART.
I'm attaching the SMART Health Results and the Error Scan Results.
I found out the SSD is an OEM from Crucial/Micron. HP puts their name on it. It's a RealSSD C300, except it's modified for HP and probably other PC mfrs. It's a SATA 2 that operates at 3 Gb/s, not the 6 Gb/s that the C300 normally operates at if you were to purchase it off the shelf. I couldn't find any mfr diagnostic tools for it. That would've been really helpful. It's firmware version 0005, which is an early version.
I understand that a SMART scan which indicates the drive is in good health doesn't mean it couldn't fail tomorrow. Case in point: I tried running HDD Regenerator and SpinRite on the drive but both indicated there was a delay, right at the first block/tile, and they never really started. I left the HDD Regen running for an hour and it was 0.0%. SpinRite (on level 1 and 2) was also an hour, maybe 2 hours, and it was 0.02 or 0.02%, something like that. The point is I couldn't even run those tools. The SMART health scan does show that bad block/sector reallocation was ever done on the SSD.
The SMART error scan displays -- I counted -- 113 errors. As you can see, there is an error in the very first tile of the scan, which might be why the HDD Regen and SpinRite both essentially hung. I didn't take a screen shot of it, but there was a feature in the error scan which can show you were scanning was "fast" and "slow". I saw more "slow" than "fast". And, interestingly, GNU ddrescue also shows 113 errors. I checked the GNU ddrescue manual again and I think it refers to these errors as areas. The cluster size for ddrescue was set at the default of 64 KB. In HD Tune, the tile size is 97 MB for my SSD, but I don't see where it indicates the block size or how it would show if I have multiple bad blocks in one tile.
For GNU ddresuce, I had 113 errors, with an error size of 458 KB. That's roughly 4 KB per error, or 8 512-byte sectors. The SSD is using NTFS, with a block size of 4KB. Is that NTFS 4 KB block size what GNU ddrescue and HD Tune are referring to when they indicate the error count?
Would you say my SSD drive is in good health, with everything stated thus far?
Lastly, these errors are of a physical or logical nature or possibly both?
Thank you.
| Attachments: |
File comment: Error Scan Results
File comment: SMART Health Results
