 Post subject: WD2502ABYS(IBM System X)
PostPosted: February 26th, 2014, 23:22
hi guru,
i got IBM System X model: WD2502ABYS-23B7A0. When i connect to PC, it spins well(sounds fine and not click) but PC bios cannot detect it. it spins for while then stop. when i connect to imager(Deepspar), it also cannot detect. does anyone can tell me it's firmware or mechanical problem?
 Post subject: Re: WD2502ABYS(IBM System X)
PostPosted: February 27th, 2014, 3:21
Could be either to be honest.
If you're 100% sure there are no unusual noises (like quiet ticking or "sweeping") then firmware is the more likely culprit.
You'll need pc3k or similar to solve that.
PostPosted: February 27th, 2014, 4:17
You need right tools to handle this drive.
Just by what you have posted no one can tell you whether its a FW or Mechanical or a Electronic Fault. Max you can confirm FW problem by ROM swap.
 Post subject: IBM System X data recovery
PostPosted: February 27th, 2014, 6:16
According to your description that's most likely either heads or SA problem.
And further remote diagnostics is more of a guessing, indeed.
Users browsing this forum: Google [Bot] and 193 guests
