 Post subject: Seagate ROM transfer is this compatible
PostPosted: February 28th, 2014, 17:31
Is possible to move ROM from donor to patient.
Each bord have different MCU and ROM
Donor(D) date 07066 ; patient(P) 07084
 Post subject: Re: Seagate ROM transfer is this compatible
PostPosted: February 28th, 2014, 17:34
Unlikely...the processors are completely different.
PostPosted: February 28th, 2014, 17:47
ISTM that the two PCBs should be compatible. Both MCUs carry what appears to be a Seagate part number (100356070), which would suggest that STMicroelectronics and Agere are second sourcing each other.
The PCB stickers also have an identical Seagate number (100389143).
PostPosted: February 28th, 2014, 18:11
If you have the skill you can swap them. The question is "what is this exercise about?"
Compatibility of PCBs?
DataRecovery.bg
PostPosted: March 1st, 2014, 0:26
Fzabkar said it all.
They are compatible you can go ahead with ROM swap for sure
PostPosted: March 1st, 2014, 3:14
Thank you Rob, FZabkar and Samo for your replay.
ROM chips near MCU are also different type
PostPosted: March 1st, 2014, 5:06
Should be fine.
Users browsing this forum: No registered users and 72 guests
