 Post subject: ROM needed - ST35000820AS FWSD35
PostPosted: March 1st, 2014, 6:34
Hello, i need rom for this Barracuda 7200.11 drive:
Model: ST3500820AS
FW: SD35
My firmware database:
 Post subject: Re: ROM needed - ST35000820AS FWSD35
PostPosted: March 1st, 2014, 7:45
S/N: 9QM0....
 Post subject: ROM or loader? - ST35000820AS FWSD35
PostPosted: March 1st, 2014, 13:59
Are you looking for a ROM or for a loader?
If that's ROM, then I'm a bit curious: what do you intend to get from it? Adaptives?
PostPosted: March 1st, 2014, 14:43
i think that he is finding donor ROM to access firmware AREA, then he will try to download copy of ROM from modules and try to write on ROM chip.
Waqas Ali
www.sediv.net
PostPosted: March 2nd, 2014, 3:49
Waqas Ali
http://www.sediv.net
are you sure about that?
PostPosted: March 2nd, 2014, 5:23
I really don't know if is possible to get rom again because some people say that if you lose F3 rom it's impossible to rebuild it, but someone else say that is possible to get its copy on SA (mod15 on CPR or CPF) if you can get access to SA with generic rom which has same fw version of same model donor drive.
Opinions?
Is this a lost case or can be done something to recover data?
Client lost original pcb few months ago...
PostPosted: March 2nd, 2014, 7:06
Opinions?
To answer your Q here
you may think of 2 things
1- Size of ROM
2- Size of Mod15
then you will close the subject by yourself
Many pretend to KNOW few only KNOW, and those few WILL keep it for themselves.
do not expect the Magician to reveal his SHOW Secret, or what is the point of the show from the 1st. place.
"The secret to creativity is knowing how to hide your sources." - By: Albert Einstein
PostPosted: March 2nd, 2014, 14:46
Opinions?
Dipende solo dal portafogli e se si vogliono veramente recuperare quei dati.
Everything depends on money / budget and if data is really needed .
PostPosted: March 2nd, 2014, 16:33
Could you explain how to go about this, and does SeDiv have such a feature?
FWIW, I notice that the SA contains MODs 4, 6, and 7 which appear to contain the necessary CAP, RAP, and SAP parameters that might be used to attempt a reconstruction of the ROM.
4 Servo Adaptive Parameter (SAP)
6 Read Adaptive Parameters (RAP)
7 Controller Adaptive Parameters (CAP)
A quick examination of an SD1A resource dump would suggest that the ROM's CAP and RAP are very similar to their SA versions, but the SAP has significant differences.
 Post subject: Re: Seagate F3 ROM needed - ST35000820AS FWSD35
PostPosted: March 2nd, 2014, 22:45
It's Sunday night, so I can't check myself to be 100% sure, but if I recall correctly, Mod 15 isn't stored on the platters, it's in the ROM.
But again, re-check this yourself, as I speak from memory now.
Additionally, same firmware version won't be enough for that.
PostPosted: March 3rd, 2014, 11:34
I have quite little knowledge on this subject but, are not the adaptives necessary to get access to the platters ? If platters can be accessed using generic ROM (without the adaptives), what is the point of transferring those U12, IC602 or U5 chips to replacement PCBs ?
Users browsing this forum: No registered users and 214 guests
