 Post subject: Seagate Momentus Thin
PostPosted: March 2nd, 2014, 9:38
Hello!
I have Seagate 320 GB Thin drive, needs heads replacement. The problem that the drive encrypted with endpoint.
Model : ST320LT007
FW : 003DEM1
Is there a way to disable the endpoint encryption to retrieve the data from the drive after heads replacement.
Thanks in advance.
 Post subject: Re: Seagate Momentus Thin
PostPosted: March 2nd, 2014, 17:34
what ver endpoint is this?
Either way, from what I know, it is not possible to disable the encryption on the fly, unless it a very new version which I do not have experience with and things have changed. For the older versions, it needs to actually go through the decryption process.
PostPosted: March 8th, 2014, 13:15
Thanks for the reply. :)
Case solved.
Users browsing this forum: No registered users and 304 guests
