 Post subject: Barracuda 7200.12 1T failed
PostPosted: March 3rd, 2014, 11:38
Suddenly my Seagate Barracuda ST31000528AS internal backup drive is no longer detected by the bios. When I do a reboot it starts to spin up, clicks 3 times, then shuts down. The drive is a couple years old and had had no physical trauma inflicted. I inspected the PCB and the only discernible damage is what looks like overheating on the contacts (photos attached). Is there a possibility replacing the PCB with bios transfer might allow me to copy the data or is it time to take it to a local pro? Thank you for you help.
 Post subject: Re: Barracuda 7200.12 1T failed
PostPosted: March 3rd, 2014, 11:46
The three clicks and a spin down usually suggests that the heads have failed. If you value your data, get it assessed by a professional lab before more damage is caused.
PostPosted: March 3rd, 2014, 14:22
You said that it is a backup drive; why do you toss it and make another backup ? Or rather make another backup and then toss it ?
PostPosted: March 4th, 2014, 3:23
Contacts on the pcb look very oxidized, try removing the oxidation hovering over them with a pencil eraser.
If this does not solve the problem then it means that very likely heads are damaged.
Be careful not to touch the components!
My firmware database:
PostPosted: March 6th, 2014, 5:21
The condition of the head contacts is what we see every day, nothing surprising about it. 99% head failure based on symptoms.
Data Recovery Cape Town
Users browsing this forum: Majestic-12 [Bot] and 199 guests
