 Post subject: LED000000CC Problem that solution can't fix
PostPosted: February 24th, 2014, 10:46
Hi Guys,
I have a Seagate ST3500820AS 7200.11 that have the Firmware problem LED0000CC that usually we can fix with the PC3K solutions.
But in this case i can't, i run the solution and make a short-circuit in control points in PCB write/read.
After that the drive can't became ready and run the solution, only show again the terminal log of LED000000CC FAddr:0024A51.
Have any one this problem already?
Thanks for your time :)
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: LED000000CC Problem that solution can't fix
PostPosted: February 24th, 2014, 10:57
Did you inspect the drive internally (within a clean room) to ensure that the heads haven't crashed?
PostPosted: February 24th, 2014, 11:11
Yes the drive is ok, doesn't have heads damaged and headcrash.
PostPosted: February 24th, 2014, 11:18
No thanks, my intention is to do it my self :)
PostPosted: February 26th, 2014, 11:33
plz try this in hyper terminal
PostPosted: March 6th, 2014, 12:48
People i do it, i solve the problem. Now i'm recovering data :)
PostPosted: March 6th, 2014, 18:41
What exactly did you do? I see no steps to follow posted publicly
PostPosted: March 7th, 2014, 4:57
In the short circuit can't make the PCB unblock the read/write channels so i made it isolating the motor connections. Drive can read the FW and have sectors access. :)
Users browsing this forum: Google [Bot] and 228 guests
