 Post subject: Western Digital PCB Compatability/Availability Rare PCB
PostPosted: March 9th, 2014, 21:42
Hi I have a Western Digital WD3000 300GB IDE Hard Drive that failed,
Apparently I have the White Unicorn of WD PCB's because Ive been looking for Months and I cannot find them anywhere.
April 2005
PCB# 2060-701314-000 REV A on board
PCB# 2061-701314-AA01 XW on Sticker
All I can find is 2060-701314-002 REV A or Maybe a 2060-701314-001 REV A every now and then.
Can I swap U12 onto a 2060-701314-002/001 REV A? are the board close enough? I can't find an exact match for whatever reason due to it popularity/rarity/age
I swapped boards and my dead hard drive did spin up so I know it's PCB related. any help would be appreciated. thanks in advance.
 Post subject: Re: Western Digital PCB Compatability/Availability Rare PCB
PostPosted: March 10th, 2014, 3:27
If the donor PCB has same MCU and motor chip, then it's definitely worth a shot!
PostPosted: March 10th, 2014, 13:13
I swapped the Donor PCB onto the the Original HDD and it did spin up. the original PCB did not power up and spin. is there somewhere I can get an external Rom Programmer? that would be optimal instead of trying to sauder the U12 off and on another board.
PostPosted: March 10th, 2014, 13:40
I actually just picked up a EZP2010 USB programmer off eBay so I'm hoping it will allow me to copy and re-write the U12 rom chips without saudering them off the boards. it looked like it came with 4 adapter boards that allowed you to copy while attached to the PCB.
PostPosted: March 10th, 2014, 15:52
It spins up with the donor PCB with no Clicks. I'm going to try to use the ezp2010
I just picked up. if it doesn't work I will take you up on your offer and send it out. thanks for the help
PostPosted: March 10th, 2014, 16:08
I would practice reading, erasing and writing on your donor PCB. Read the chip several times and compare the copies to make sure that they are identical. After erasing and rewriting the donor, I would then confirm that your patient drive still spins up with the donor PCB.
Users browsing this forum: Majestic-12 [Bot] and 345 guests
