 Post subject: Seagate 7200.9 shift track
PostPosted: March 25th, 2014, 19:01
Is it possible to shift module track in SA area.
I try to write ATA module, and report me, that was succesfully, but reading failed
Any suggestion, how to fix write and read of ATA module.
Thank you
 Post subject: Re: Seagate 7200.9 shift track
PostPosted: March 26th, 2014, 10:26
If you self-scanned your drive and get a message "Unable To Load Overlay" than you either not writing it the right way or your drive may have other (head?) problems. Whichever is your case, shifting tracks will not help. As regards your question, the only way I know to relocate system area is to self-scan your drive from N2,,22 (what you might have already done) after you backuped the drive's firmware.
Those who know don’t talk. Those who talk don’t know.
PostPosted: March 26th, 2014, 17:40
I switch heads back to donor and everything Works normal.
Switch heads back to patient drive is in usy state on HDD4Seagate.
I perform following terminal command and get error on CTRL+U command. Any suggestion to fix. I need to recover data
Thank you
^U
^L
^A
k
y(CTRL+R)
x
Terminal output
20140326_1810_tonka2.txt [2.32 KiB]
Downloaded 569 times
Users browsing this forum: Google [Bot] and 231 guests
