 Post subject: WD3200AAJS BSY
PostPosted: March 26th, 2014, 14:30
This WD3200AAJS stays BSY (busy) on PC3000 until
the red ERR light comes and then stops spinning.
I saved all the resources of the Donor controller card.
I put the Patient card on the Donor HDA and it becomes
Ready (after some clicking). It is identified properly as
Pinclite model, but can only start in Kernel mode with-
out errors. I am able to save the ROM and ROM modules
from the Patient controller to the database.
With the Donor card on the Patient HDA, I tried the
"ROM recovery" selection from the Tests menu. It starts
to run but fails halfway through because one of the
steps is to re-power of the drive - which fails because
nd that fails and the drives is BSY once more.
I reversed the procedure and was able to repair the
Donor card using Rom recovery.
I opened the HDA in our clean room and everything
looks brand new and perfect.
Now, I'm stuck.
Can someone offer me a next step??
Thanks!
-Oy
 Post subject: Re: WD3200AAJS BSY
PostPosted: March 26th, 2014, 15:07
It seems drive has problems with modules in the SA. Typically mod 11, at least.
PostPosted: March 27th, 2014, 12:03
Thank labtech. Any idea how to fix it? - based on the current
state, I admit I'm lost here.
Oy
PostPosted: March 27th, 2014, 12:17
You claim you have PC3000. Should be fairly easy in theory.
Not sure what resources you have, but the first step is confirm mod 11 is the problem.
PostPosted: March 27th, 2014, 13:32
Thanks again labtech.
Yes I have it, but I only get kernel mode to
read ROM modules and 11 isn't one of them.
I cannot get to the SA, which is where mod
11 resides, I guess.
what would you do next...
-Oy
PostPosted: March 27th, 2014, 13:35
use loader or hot swap procedure
PostPosted: March 27th, 2014, 13:51
How can he use LOADER while the HDD is BSY? Hotswap might help.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: March 27th, 2014, 14:52
As far as I recall, this is ready state with ERR. Could use loader in this scenario.
Could be wrong... Perhaps OP wants to post of picture or clarify.
PostPosted: March 27th, 2014, 22:38
Does the patient drive stay spinning with the donor PCB?
http://www.datasaversllc.com
Users browsing this forum: Google [Bot] and 220 guests
