 Post subject: Advice on camera modules
PostPosted: April 8th, 2014, 20:45
Hi guys,
Just after a bit of advice before I send some components off and waste a DR companies time.
I dropped a digital video camera and sent it off for repair. I was told it was an uneconomical repair but the technician said he could remove the memory modules for me to send away for DR.
He supplied me with 2 small boards, pictures of both sides of each board are following.
I hope the pics are clear enough.
Is data recoverable from these memory modules?
If so, any recomendations for a reputable company in Victoria Australia would be appreciated.
Thanks in advance.
Azin
 Post subject: Re: Advice on camera modules
PostPosted: April 8th, 2014, 23:42
I believe so, could you please list the chip numbers on the second picture (or all if you feel energetic) as they are hard to make out and important.
I am in Adelaide and work with Flash, and have helped a number of people on here that have posted to me.
Welcome the chance to help you on this.
regards
PostPosted: April 9th, 2014, 20:31
If you can tell us the model number of the camera, I may be able to locate a service manual with circuit diagrams. That will tell us the pinout of the modules.
PostPosted: April 9th, 2014, 21:12
Thanks for the prompt reply guys,
Will post camera model and chip details when I arrive back home in a couple of days.
PostPosted: April 9th, 2014, 21:24
Here is the Level 2 section of the service manual for a likely looking camera:
http://www.exitequipment.com/files/doc/ ... 009.12.pdf
http://elektrotanya.com/sony_hdr-cx500_ ... nload.html
Here is the Level 3 section:
The "MM-083" card appears to have a standard 8-bit MMC interface with a 2.8V supply voltage. Its diagrams can be found in the Level 3 manual.
And for completeness ...
PostPosted: April 9th, 2014, 22:34
BTW, I have seen the business cards of these guys in a few Computer shops in Adelaide. Going on the website info, and anecdotals from a shop here, they seem ok, though no first hand experience : http://www.techneticsdata.com.au/
cheers
PostPosted: April 10th, 2014, 0:48
cheers
ISTM that the OP's case would be within your own capabilities.
PostPosted: April 12th, 2014, 7:57
cheers
Thanks Franc, I believe so, and would welcome the chance to work on this interesting case. The OP mentioned wanting a DR company in Vic, so I thought it only fair to mention and let him at least weigh up the options.
Still interested to know the chip numbers.
PostPosted: April 12th, 2014, 17:18
They're in the service manual.
PostPosted: April 12th, 2014, 17:41
IC8701 & IC8801
THGBM1G8D8EBAI2
32GB eMMC
http://datasheet.octopart.com/THGBM1G8D ... 973698.pdf
http://pdf.datasheetarchive.com/indexer ... 020864.pdf
SE6601
21kHz/23kHz
Pitch/Yaw Sensor
PostPosted: April 13th, 2014, 20:22
Thanks for being patient,
fzabkar, I don't know how but you nailed the camera model. HDR CX520.
HaQue, If you still need the numbers on the chips it might take another day, I'm going to need to source a magnifying glass or digital microscope. I'm more than happy to send them to you in SA if this is within your field.
Appreciate the input so far.
PostPosted: April 13th, 2014, 20:34
I searched for PDF documents containing "VC-575" (the number on the larger PCB).
http://www.google.com/search?q=%22VC-57 ... 3Apdf+sony
PostPosted: April 13th, 2014, 23:04
There are a few people that really understand searching the interwebs. We lost Fravia a while ago to illness, but I think Franc has an equal talent for finding information.
I'll send a PM
PostPosted: April 18th, 2014, 19:19
If this way don't work i have another solution. Good luck!
data recovery service[/b]
PostPosted: April 18th, 2014, 21:51
Buy a second camera and swap the memory card?
PostPosted: April 20th, 2014, 0:49
what different with your first provide? it same.
if chip working. your way will work.
