 Post subject: Anyone got an image of this?
PostPosted: April 14th, 2014, 6:03
Hello All,
anyone got this memory picture from inside?
Sony SxS Memory
Ref. Image from outside: http://handheldfilms.com/wp-content/upl ... pro-64.jpg
i was wondering about knowing whats inside?
if anyone got similar case plz post the image of inside, since Google image results ended with Zero
thnx
 Post subject: Re: Anyone got an image of this?
PostPosted: April 14th, 2014, 8:11
This is a first for me...but, I see headache written all over it.
PostPosted: April 14th, 2014, 9:02
No photo, but I'm guessing it's going to be similar to a 32Gb version. Of which there is one posted and recovered on Soft Center forum. That one has 8x chips inside.
PostPosted: April 14th, 2014, 9:25
Probably you could be the first to post the photos of its innards.
These are infrequent guests at our lab, I'd say we've seen 5, maybe 10 of them. Usually come from a film production companies.
But all the cards we worked with were OK physically.
If I recall correctly, they are positioned as superfast / superreliable and priced accordingly therefore.
If a client agrees for you to destroy one (although you'll need at least two, I believe), then data is likely to be important.
PostPosted: April 14th, 2014, 10:08
@ pcimage i was checking their forum, but cannot find the post you are referring?
@ Dmitri Well, i just ordered ONE for my Curiosity from Amazon
will post the details when it comes
seems as i expected few only got such cases like this, not well common
thank you all :agree:
PostPosted: April 14th, 2014, 10:44
coincidentally I also have one coming from a friend in UK as I was reading about them last week and didn't have one.. so thought I better rectify that ;)
PostPosted: April 14th, 2014, 11:37
Here you go...
http://www.flash-extractor.com/forum/vi ... hlight=sxs
PostPosted: April 14th, 2014, 19:11
You're a tough guy :)
The only solution we've seen for these cards is the one that pcimage mentioned above, I'm curious whether it will work with the modern, 64 GB revision.
If I were you, I'd also do the following:
- contact the seller (if you have placed an order with some seller there, not with Amazon directly) and ask to to hold aside one more card from the same batch. Considering the price and that you've already purchased one, I believe they'll agree;
- confirm that seller provides USB reader with the card. Our movie-makers are probably getting them as a corporate buyers, but besides that those readers are virtually impossible to buy separately (at least here).
Anyway, curiosity is always praiseworthy, good luck .)
PostPosted: April 14th, 2014, 20:19
The controller the layout fitted is D3469GX, which is also use im Sony MS Pro Duo devices. Doesn't mean that is the controller chip though, maybe just compatible. DR should be straightforward though, but with more dumps like an SSD. Wouldn't be surprised if it is actually a SSD in a PCIe interface.
one page says this:
ExpressCard SSD
Aparently the generic version of SxS, SSD simply stands for Solid State Drive. The size of a PCI Express card, uses the PCI-E controller in the ExpressCard host, etc. Said to be compatible with all ExpressCard 34 or 54 slots, with speeds over 45 MB/s.
Made by: Delkin, Lexar.
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=3865&extra=page%3D1%26filter%3Dsortid%26sortid%3D1%26searchoption%5B11%5D%5Bvalue%5D%3DD3469GA%2520%26searchoption%5B11%5D%5Btype%5D%3D%26sortid%3D1
[url]http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=3865&extra=page%3D1%26filter%3Dsortid%26sortid%3D1%26sortid%3D1/url]
http://flash-extractor.com/forum/viewtopic.php?t=6609
http://www.flash-extractor.com/library/Other/D3469G/
PostPosted: April 15th, 2014, 2:03
@ pcimage i saw the link before, but cannot find the IMAGE of the card ( i mean from inside controller and so...)
@ Dmitri Well i bought one from amazon yesterday, its kind of defected for the one who sell it, he wrote that the card WRITE-PROTECT pin is BROKEN and it is not in READ-ONLY mode (which is fine for me) its 16GB SxS got it for about 90$ heheh
i guess its a good deal for lab testing.
@ HaQue again, cannot see the inside Image of it as i wanted
@ the end, i will wait for my card and will post later whats inside it.
thank you all again
PostPosted: April 17th, 2014, 2:37
here you go
data recovery service[/b]
PostPosted: April 17th, 2014, 9:10
thnx for the images sunny
