Forum rules
 Post subject: Hitachi TravelStar 7K500-250 HTS725025A9A361 NVRAM
PostPosted: April 4th, 2011, 11:04
I have a Hitachi Travelstar 2.5" drive,
[url]http://ldf4n6.serveftp.net/images/IMG_1487.JPG
[/url]
Model: HTS725025A9A361
Made In: Thialand
P/N: 0A73352
MLC: DA3247
The top 2 lines of the PCB are:
http://ldf4n6.serveftp.net/images/IMG_1488.JPG
0A71428
DA3005A
I ran diagnostics on the drive using an Atola. I need a donar PCB and
maybe a head stack replacement as well. After some research it
appears that many of the new Hitachi drives store adaptives and other
information in the NVRAM stored on the PCB which will need to be moved
from the original PCB to the donar.
I'm not sure how to identify the NVRAM chip. Research I've come
across says the NVRAM chip is an 8-post chip and may be the U3 or U6
chip. Anothers say its the U5. Can someone identify and tell me how
they identified the NVRAM Chip on my PCB?
http://ldf4n6.serveftp.net/images/IMG_1491.JPG
http://ldf4n6.serveftp.net/images/IMG_1493.JPG
 Post subject: Re: Hitachi TravelStar 7K500-250 HTS725025A9A361 NVRAM
PostPosted: April 4th, 2011, 12:18
NVRAM is U6 on this one.
Dmitry
PostPosted: April 4th, 2011, 13:09
Dmitry, thanks for your quick response.
Can you explain to me how you know this is the NVRAM chip?
Thanks,
Dave
PostPosted: April 5th, 2011, 9:07
Dave,
Generally, 25... series chips are high capacity EEPROM chips. 93... series are low-capacity, and are used to store some parameters, hence it could be identified as an NVRAM chip.
Anyway, if you simply download .pdfs for those chips, everything becomes obvious. Here's an example for 93C76: http://ww1.microchip.com/downloads/en/D ... 21796K.pdf
Dmitry
PostPosted: April 10th, 2011, 6:50
HDD IC database:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
PostPosted: August 18th, 2011, 11:44
Hi Folks,
I'm new here and need some information on testing the electrcal connection from the pc board to the heads. I don't want to just put an ohmmeter on it as the test current may write something on the head that is unwanted. How should this be tested.
Thanks,
CNM
PostPosted: April 21st, 2014, 23:06
Banned User
both U3 and U6 are the NVRAM.
PostPosted: April 22nd, 2014, 4:14
a) No they're not
b) Thread is ~3 years old
Users browsing this forum: No registered users and 82 guests
