 Post subject: Dead Seagate HDD. Cant find replacement.
PostPosted: May 2nd, 2014, 4:40
dead HDD:
Seagate Medalist 4321 (Drive parameters: 8894 cylinders, 15 Heads, 63 sectors, 8.404.830 addressable sectors)
Model Number: ST34321A
Serial Number: GY441562
Part Number: 9K2003-650
Firmware Number: 3.29
Lot Number: A22311
Configuration Level: TAX01
Date Code: 9919
Site Code: WV
replacement working HDD bought on eBay:
Serial Number: VY771640
Part Number: 9K2003-653
Firmware Number: 3.41
Lot Number: A46312
Configuration Level: TCV01
Date Code: 9926
Site Code: ML2 V
My dead HDD symptoms: not spinning at all
I bought this working donor on ebay.
Tried live swap (windows xp, power management->sleep hdd after 3 mins). After i wake up pc (old hdd swapped pcb out of replacement hdd) - first of all hdd not spinning but after 1min begins to spin and hdd goes out from my computer and disk management. Then i go shutdown, computer is shutting down for a long time.
Can you help me ? Is this replacement hdd not suitable ?
 Post subject: Re: Dead Seagate HDD. Cant find replacement.
PostPosted: May 2nd, 2014, 7:05
You are going about it the wrong way.
"Live swap" like this will never work.
You either need a compatible (same FW version at least) PCB or swap the "ROM" chip over (usually a AT29C1025 48-pin TSOP) from the dead PCB to the donor.
But first, check any TVS diodes and fuses.
Post a photo if you like?
PostPosted: May 2nd, 2014, 7:13
Or... I have a (99% surely) suitable donor drive if interested?
PostPosted: May 2nd, 2014, 7:42
Thank you for your answer.
if i swapped rom chip, then should i do "live swap" or just swap ?
I will post PCB photo later today
PostPosted: May 2nd, 2014, 7:44
Just swap.
"live swap" is totally useless to you, forget about it.
Yes, post a photo of PCB
PostPosted: May 5th, 2014, 15:40
I cant find original pcb. I dont understand how i managed to lost it.
What price incl. shipping ? Are you sure about compatibility ?
PostPosted: May 5th, 2014, 15:50
pcimage wrote:
Just swap.
what circumstances at is "live swap" good to go ?
PostPosted: May 5th, 2014, 16:29
Better find it, you'll need it...
http://www.rescue-it.se
PostPosted: May 5th, 2014, 16:36
Why? Pcimage seems to think that a straight PCB swap is all that is necessary.
PostPosted: May 6th, 2014, 9:22
I cant find.. Pcimage told that he has got the compatible one
PostPosted: May 6th, 2014, 12:03
You have PM
Users browsing this forum: No registered users and 40 guests
