 Post subject: Need ROM and loader from WD5000AZRX-L4H
PostPosted: May 9th, 2014, 7:57
Something's wrong with this HDD's ROM (SA translation error - UBA 0 out of translation + reading errors on ROM modules 30 and 47).
I need a matching FW ROM and possibly a loader. I'd really appreciate any help.
Here are the details:
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 01.34G
ROM generation.......................... : 01.34G
Link table version...................... : 22.30.
Consolidated ROM version................ : 00010034
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 208 636
SA regions address...................... : spared
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number............................ : 2
Heads number in use..................... : 1
Switched off heads...................... : Yes
Heads map............................... : 0
ROM Firmware version.................... : 00010034
The drive is a TrailXLS, model WD5000AZRX with family + configuration code 00L4HB0.
Thank you very much in advance.
Users browsing this forum: No registered users and 82 guests
