 Post subject: remote help - modules repair
PostPosted: May 13th, 2014, 3:58
Hello
We have WD 500GB Royl drive
There is unreadable P-List and ATA Module #11
We cannot rewrite the ATA module.
We have Salvation WD HD doctor tool
Can somebody help remotely ?
 Post subject: Re: remote help - modules repair
PostPosted: May 13th, 2014, 22:03
Prepare donor for hot-swap
PostPosted: May 14th, 2014, 8:53
Spildit wrote:
Can't do the Module Relocation neither the module auto fix
It was also necessary to try to write (move) modules in Safemode. :wink:
PostPosted: May 14th, 2014, 9:35
It's a complex case as the failure is worse than it seems. Remote won't do it. The drive needs a lot of pampering even under the assumption the firmware issue is resolved remotely. And it looks like it needs a new set of heads anyway.
PostPosted: May 14th, 2014, 10:43
Banned User
Try Reserve ARCO Calibration if you have WDR with some experience.
PostPosted: May 14th, 2014, 10:49
Spildit wrote:
Tryed withou loading from hdd (perm ovl). Get ERR and ABRT.
What is the error code ?
Tryed to write to different module address, including to ss log, to replace that space with mod 11.
Load the modified 01h and 11h ?
No luck. Can't write mod 11. Tryed also to power off/on first when new location is set.
:oops: Unfortunately I can't explain in English. Sorry. :oops:
PostPosted: May 16th, 2014, 6:04
Banned User
I can teach you it can solve module writing error with no data lost.
Spildit wrote:
Would this be SAFE for data ?
DATA is needed.
Users browsing this forum: Google [Bot] and 50 guests
