 Post subject: Seagate Barracuda 7200.11 0 capacity
PostPosted: May 14th, 2014, 16:10
how to fix Seagate barracuda 7200.11 0 capacity to recover data.
FW:HP12
 Post subject: Re: Seagate Barracuda 7200.11 0 capacity
PostPosted: May 14th, 2014, 16:27
no terminal output
PostPosted: May 14th, 2014, 16:51
if I isolate motor, turn on and press CTRL+z
then I get F3 T>
But without isolator there is no terminal output. Terminal is locked
PostPosted: May 15th, 2014, 2:16
Also, on 7200.11 drives with HP firmware will not work the translator command until you don't insert the congen command first, of course assuming that the issue is due only to translators
My firmware database:
 Post subject: Re: Seagate Barracuda 7200.11 0 capacity CASE CLOSED
PostPosted: May 18th, 2014, 16:14
Dear Spildit and michael chiklis,
thank you for oyur replay and suggestions.
I manage to fix drive and recover all files
Best regards
Jure
