 Post subject: All hex value are same
PostPosted: May 23rd, 2014, 2:53
Hi there!
I have a patient drive "MYBook External drive" which has not detected and clicking sound while it was powered.
After a head swap, the drive was identified fine. In recovery program its show all the hex value are same from the beginning till end of the drive.
 Post subject: Re: All hex value are same
PostPosted: May 23rd, 2014, 3:27
Every single sector, including zero?
Show LBA's 0, 63 and 2048
Those in your screenshot look like encrypted blank sectors, encrypted by the USB bridge.
PostPosted: May 23rd, 2014, 4:43
Those are encrypted 0x00's. I have an eye for that! (many of us may have it, sure :wink: ). Have you changed the original PCB, or are you reading using ATA commands or through its terminal, instead of SCSI (USB) commands?
EDIT: I misread MyBook and my head thought it was a MyPassport drive. I bet you're trying to read the drive without the original MyBook enclusure. It is mandatory for DR if encryption is enabled (by default on most countries)... so again, data is encrypted and most probably that's an all-zeroes zone.
PostPosted: May 23rd, 2014, 5:36
Banned User
Did you also change the PCB? every PCB is encrypted with drive firmware.
PostPosted: May 23rd, 2014, 6:21
Banned User
What is wrong with my post two people are saying same thing it is a PCB issue we have hands on experience.
and you said encryption encryption for what describe.
Spildit wrote:
Wrong again...
Is it possible that you can't make a single post with acurrate information ?
PostPosted: May 23rd, 2014, 6:37
Banned User
May be you are right i don't have prove on it. is it combated with firmware or with PCB chip. but this is PCB encryption.
Spildit wrote:
The problem with your post is that the encryption is not done by the firmware. There is a specialized chip that deals with the encryption on the usb bridge. Meaning that if the drive doesn't have the usb bridge on the pcb the encryption will be dealt by the enclosure and not the drive pcb.
PostPosted: May 23rd, 2014, 7:24
What a dumb discussion!
The "PCB" can be either the HDD's own PCB or the USB bridge PCB in the enclosure, and the firmware from the enclosure's PCB is the one doing the encryption in the MyBook... :P
PostPosted: May 23rd, 2014, 8:33
To sum it all up. Get a full clone of the drive to a drive of equal size or set the HPA of the clone equal to the source. Then connect the clone to the original USB bridge. You may still need to run a data recovery program afterwards, depending on the effects of bad sectors.
Good luck.
Users browsing this forum: Bing [Bot] and 39 guests
