 Post subject: how i can made usb write protected
PostPosted: May 23rd, 2014, 10:53
how i can made usb write protected not only on my pc and for others pcs that
i used usb in it
coz i tried some programs do that but found work only on my pc
for that i need one to can protect the usb from virus from other pcs
& don't need for scan & re copy what i lose from virus damage files
 Post subject: Re: how i can made usb write protected
PostPosted: May 23rd, 2014, 12:08
i used usb in it
Use CUSTOM MADE FLASH - with CD partition (for example)
OR
buy expensive customized flash (HW) + SW which comes with it and do what u needed to program it to do (i think german made)
PostPosted: May 23rd, 2014, 13:40
how that ?
PostPosted: May 24th, 2014, 3:51
You can find the tools at places like flashboot.ru to modify drives firmware - but be warned - it isn't easy, you will probably kill a few drives.
BTW a simple Google and stuff like this is found.:
http://www.kanguru.com/storage-accessories/kanguru-ss3.shtml
Another easy way is get a USB-SD Card adapter and use SD Cards with a write Protect switch. You can get ones in the shape that closely resembles a flash drive, so not much different. SD Cards are easier to store too.
There is a registry hack also that you can use. Write a small .reg file to enable, and another one to disable, then you can run it, use your drive, then run it after you have finished to re-enable writing to USB.
PostPosted: May 24th, 2014, 10:17
that is nice way
but i need that operation made automatically
to be faster more than any file copy to himself to usb
and maybe i forget to reback write mode
forthat wn plug usb that no write mode work then wn unplug re back to normal mode
any thing like .bat file to do that
PostPosted: May 24th, 2014, 12:11
ahmedali wrote:
that is nice way
ANY stupid anti-virus will block that? sometimes windows itself,
better go for either option1 or 2,
good luck
PostPosted: May 24th, 2014, 16:47
Option 3 is to buy any cheap flash drive, locate the controller's Write Protect pin, and then add your own switch. If you intend to use your flash drive as a permanent read-only archive, then you could solder a permanent link to ground.
See the following Silicon Motion reference circuits:
download/file.php?id=8221&mode=view (SM3257EN_application_circuit.jpg)
download/file.php?id=8220&mode=view (SM3255QF_application_circuit.jpg)
The nWPRO pin is the one you would need to hack.
PostPosted: May 26th, 2014, 18:54
You also can use diskpart
Win+R
Diskpart
List disk
"than select your disk" > sel disk 1
"list partitions" list part
"select partition" sel part 1
type > att vol set readonly
to remove att vol clear readonly
http://social.technet.microsoft.com/For ... progeneral
more info here i use that works well.
PostPosted: May 26th, 2014, 20:21
einstein9 wrote:
ahmedali wrote:
that is nice way
good luck
No, The Active directory domains I manage have this reg hack sent out Via group Policy, and there is McAfee AV in service.
PostPosted: May 29th, 2014, 20:13
Win+R
Diskpart
List disk
it's work in same pc not different one
Users browsing this forum: No registered users and 17 guests
