 Post subject: Accidentally formattet SSD containing NTFS partition to ext4
PostPosted: May 27th, 2014, 22:57
Hi, I friend of mine accidentally formattet his SSD disk which containing a NTFS partition and changed the new file system to ext4
He said he didn't use any low level formatting techniques and the formatting process finished quickly.
I got an image of the entire disk created with TestDisk which I has been messing around with using various data recovery tools.
However, no one have been able to return ANY files.
I this case i opened the .dd file with R-Studio and ran the scan process, and it only see an ext4 file system with only lost+found folder
I do not have much experience with data recovery at all
 Post subject: Re: Accidentally formattet SSD containing NTFS partition to
PostPosted: May 28th, 2014, 10:22
If R-Studio has scaned all image file, then the image file not contains data.
PostPosted: May 29th, 2014, 10:05
Try to image the SSD disk with r-studio, not with testdisk.
Then work with r-studio image, if you still don't see any folders inside the image try to build regions in r-studio (if you know how)
My firmware database:
 Post subject: Re: Recover SSD NTFS partition formatted to ext4
PostPosted: May 29th, 2014, 23:18
I suggest we declare May as Month of Unconscious NTFS -> Ext Migration on HDDGuru:
http://forum.hddguru.com/viewtopic.php?f=1&t=28547#p196563
http://forum.hddguru.com/viewtopic.php?f=1&t=28725#p197793
Users browsing this forum: No registered users and 32 guests
