 Post subject: Polite request for help finding a roms and modules
PostPosted: March 3rd, 2014, 0:16
Hello everybody, this is my first post on the forum.
I have to hdd that I just cant find resources for, I own a PC3000 and I cant find these in the database either and I would appreciate any help.
I need a ROM for
WD2002FAEX-007BA0
DCM HANCNV2AAB
s/n: WCAY01008792
WD caviar black 21 JAN 2013
Sadly I don't know the fw version as the original chip got completely fried along with the motor controller on my original PCB, so I'm willing to do tryouts with any ROMS you might have sometimes I get lucky. I do have fw 00050065 and its no good.
Second one is a
Toshiba
MQ01ABD100H
drive rev: AAT AB10/ALf07M
S/N 13S6CAWAT YA6 HDKEB96T0A02 T
For this one I need full resources as I have corrupted modules.
Thank you very much and I do look forward to being part of this forum!
 Post subject: Re: Polite request for help finding a roms and modules
PostPosted: March 25th, 2014, 5:48
I need a ROM for
WD2002FAEX-007BA0
DCM HANCNV2AAB
s/n: WCAY01008792
Why dont you try a rom recovery ?
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2014, 6:04
I need a ROM for
WD2002FAEX-007BA0
DCM HANCNV2AAB
s/n: WCAY01008792
Second one is a
Toshiba
MQ01ABD100H
Here's 50063 from a WD1502FAEX, just alter the head map to suit your drive.
ROM.rar [188.41 KiB]
Downloaded 602 times
PostPosted: May 27th, 2014, 22:58
I need a ROM for
WD2002FAEX-007BA0
DCM HANCNV2AAB
s/n: WCAY01008792
Hi Zebong,
Sadly I tried every method in the book ti get any access to the SA, searching for Module 01 to try and read module by ID, hot swap etc. The only thing I can do is get a compatible enough rom that has the microjogs close enough to read at least module 01. I tried 5006D as well from a donor that I bought. (only after I get access to the SA can I rebuild the rom)
PostPosted: May 27th, 2014, 23:01
I need a ROM for
WD2002FAEX-007BA0
DCM HANCNV2AAB
s/n: WCAY01008792
Second one is a
Toshiba
MQ01ABD100H
Hi Pcimage,
It's close but still not enough! It's tricky to get through to the SA on WD ManPL family for some reason.
Eventually I'll have to try my luck at swapping the Main IC.
Thanks for the ROM!
www.falxdatarecovery.com.au
Gold Coast, Australia.
Users browsing this forum: No registered users and 17 guests
