 Post subject: maxtor stm3800210a
PostPosted: May 24th, 2014, 15:21
I replace heads, now drive show busy status.
Terminal show
Interface task reset
1024k x 16 SDRAM
TONKA2 - 1_Disk M-31 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0000
DiskAccess ReadSector EC=43 at ffffffff.00.0000
Unable To Load Overlay 00|0014
T>
How to fix, to recover files.
It's Barracuda 7200.9.
I test on two good drives to replace PSC's and I'm able to Access files.
Is it possible, that also this head is not 100% good
Thank you for any advice
 Post subject: Re: maxtor stm3800210a
PostPosted: May 24th, 2014, 16:05
Thank you Spildit for your replay,
I have only SD HDD4Seagate and Sediv
 Post subject: Re: maxtor stm3800210a, barracuda 7200.9 head swap
PostPosted: May 26th, 2014, 20:11
Terminal show
1024k x 16 SDRAM
Spin Ready
(P)PATA Reset
T>
It's either defects in the SA or the donor heads are unable to write due to the difference between them and original ones.
Do the following:
1. Using the drive, create a loader (read appcode only);
2. Load that loader with all the checkboxes enabled except head map editing;
You should get READY and be able to start reading. Should the reading process be slow with interruptions, then install another head stack, current one "isn't compatible enough".
PostPosted: May 27th, 2014, 3:28
Dear Dmitri and Spildit,
thank you very much for your suggestions. I will try.
Best regards
Jure
PostPosted: May 28th, 2014, 2:18
right now I try heads from drives which was released between 07066 and 07088.
I have drives released between 07200-07300(right now I don't have it here so date is in this range).
Is worth to try with this or better to find date close to 07066
Best regards
Jure
 Post subject: Re: maxtor stm3800210a, barracuda 7200.9 data recovery
PostPosted: May 29th, 2014, 21:25
Pay attention to the first three characters of the serial number.
PostPosted: May 30th, 2014, 2:03
Thank you Dmitri
BR Jure
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 218 guests
