Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate 7200.11 not detected
PostPosted: June 5th, 2014, 18:49
Are you trying to regen translator on level 1 ? :?
You have to give command m0,2,2,,,,,22 on level T
My firmware database:
PostPosted: June 5th, 2014, 19:02
I was in level 1, I sent the N1 command and powered down for 30-sec Then I powered back up and sent the m0... command. The prompt on the screen was F3 1>
Your instructions were:
...Go to level 1 and give command N1
Power off the drive.
Wait 30 seconds.
Power on again the drive.
Give command m0,2,2,,,,,22
Wait until finish translator regeneration...
After powering back up was I supposed to send a command prior to m0,...?
PostPosted: June 5th, 2014, 19:33
sorry...
after power on press CTRL+Z to go to level T again, then you can give command m0,2,2,,,,,22
I thought you had already the procedure, it's written everywhere.
Do it again!
Wait 30 seconds.
Press CTRL+Z (to go to level T)
Power off
PostPosted: June 5th, 2014, 21:48
sorry...
Do it again!
Wait 30 seconds.
Power off
OK, I think I may have it!!
I received several messages ending in "User Partition Format Successful"
I put the drive back into the original computer and it seems to be back.
I am in the process of setting up a NEW drive and will be moving all my data. I will let you know if I am successful.
Thank you Thank you Thank you for all your help!!
grazie di tutto.
PostPosted: June 5th, 2014, 22:06
Good move, backup everything you can :wink:
rfengineer wrote:
grazie di tutto.
Prego, non c'è di che :)
PostPosted: June 6th, 2014, 8:50
Success!! All data has been recovered and transferred to a new drive.
NOW, to see if the old drive be firmware updated and used in non-critical service. I suppose there is a thread on here somewhere on how to do this.
Thanks again. This problem can be marked SOLVED! :mrgreen:
PostPosted: June 6th, 2014, 9:04
https://apps1.seagate.com/downloads/req ... kie=en_US_
