 Post subject: WD3200BEKT relocate SA questions
PostPosted: June 6th, 2014, 14:37
I have a WD drive that seems like it has bad media in the SA.
I can read the SA tracks in composite mode to get all of the data.
If I read individual heads I get sector errors at different spots.
I would like to move the SA tracks to not use the ones with errors.
Can anyone provide guidance or advice ?
Is it as simple as moving the modules within the bad areas and
adjusting the DIR module to point to the new location ?
Here is a brief summary for head 0 of the problem areas...
Cylinder Sectors WithErrors
1 OK
2 1-2,450-462
3-9 OK
10 444-480
11 442-481
12 442-481
13 444-481
14 447
15-19 OK
20 437-476
21 437-476
22 437-476
23 437-476
24 437-476
25 439-476
26-30
31 433-472
32 433-472
33 433-472
34 433-472
35 433-472
36-256 OK
 Post subject: Re: WD3200BEKT relocate SA questions
PostPosted: June 6th, 2014, 15:08
Either that or create a smart hotswap donor with the composite read tracks.
PostPosted: June 6th, 2014, 17:10
not having a lot of luck with the hotswap.
wrote the sa tracks to head 0, wrote rom+modules
repower donor -- it goes ready
standby the donor, move the board
any access just clicks
Is there an easy way to relocate modules, or do I have to calculate aba's manually ?
PostPosted: June 6th, 2014, 18:20
Format SA end translator SA recalculation and write modules in place.
But there is a risk that to gash SA.
So hot swap safer.
Аs a good rule not to write anything on the bad HDD,
if you need the data.
Users browsing this forum: Google [Bot] and 11 guests
