 Post subject: WD thru the brush- what does this mean?
PostPosted: June 12th, 2014, 9:50
Have anybody been to the site wddisk.com?
It shows a technique referring it as "repairing WD HDD thru the brush.
After lot of search i find a reference of the word in http://item.taobao.com/item.htm?id=5590 ... 58_8935934
where it refers thru the brush means thru the USB toTTL adoptor.
Am i correct???????
 Post subject: Re: WD thru the brush- what does this mean?
PostPosted: June 12th, 2014, 10:11
wd repair through brush firmware,
basically it is factory firmware or universal firmware, Chinese people say it brush firmware.
Waqas Ali
PostPosted: June 12th, 2014, 10:44
Waqas Ali
So i'm assuming that one would load that universal firmware to the drive, acording to it's model and family, and then one would run ARCO and SS using that "new" firmware, correct ?
PostPosted: June 12th, 2014, 22:34
Whether this is better than WDR 5.3? if it is better, wherefrom it will be available?
PostPosted: June 13th, 2014, 4:09
Madoka
yes you are right,
but maximum universal firmware that you download from any website are self made, not original.
so you need to make some changes in it according to your hard disk. like self scan test id sequence, ARCO DCM parameters.
Waqas Ali
PostPosted: June 13th, 2014, 19:44
Good night,
Waqas Ali
Thx for taking the time to answer !
:cool:
PostPosted: July 1st, 2014, 23:42
I have acquired some wd-thru the brush firmware what to do with it.
I have wdr 5.3 how to proceed. How this firmware different from the wdr-modules?
PostPosted: July 2nd, 2014, 12:03
Share it with us ! :lol:
PostPosted: July 2nd, 2014, 12:23
Greetings.
Upload it to the drive replacing the correspondent modules, edit the self scan script, then run ARCO and Self Scan.
PostPosted: July 2nd, 2014, 12:42
Mr. Madoka may I request u to be a little bit explanatory, as it went beyond my head.
PostPosted: October 12th, 2014, 10:07
After long understanding - of simplified Chinese
I understand that :-
i) enter in safe mode of XP pressing F5.
ii) invoke wdr 5.3
iii) use the directory where thru the brush modules are
iv) load module 01
v) load module 02
you are done with.
I have not tries any HDD. but many are using "THRU THE BRUSH", i want complete guidance from them in my favourite WEBSITE hddguru.com
thanx
Users browsing this forum: ccc, Google [Bot], pepe and 53 guests
