 Post subject: WD usb3 recovery!!!!!!
PostPosted: June 15th, 2014, 2:47
hi
i have a hdd m password WD usb3
i doing slove slow......
i access to all sector (by terminal)
all Modules ok
heads ok
pcb ok
by cable usb3 no read sector
now hdd detecting in windows and massege formating
but i use all option recovery but no recovery
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1372
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 65.04J
ROM generation.......................... : 65.04J
Link table version...................... : 05.0F.
Consolidated ROM version................ : 00650004
ROM Modules:
Flash ROM dir reading................... : Ok
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5
ROM Firmware version.................... : 00650004
Service area:
Permanent overlay....................... : Loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
plz my help
thank you
 Post subject: Re: WD usb3 recovery!!!!!!
PostPosted: June 15th, 2014, 8:41
did you try DE for imaging this drive ?
have you tried changing head map ?
Data Recovery Pakistan
PostPosted: June 15th, 2014, 8:56
Drive in DE with USB cable sector in the wake of three black display
However, terminals in green, but the speed is very very low
An alternative method, and I donot know it.
PostPosted: June 15th, 2014, 10:41
sorry i did't really understand it, can you please explain it little more.
If you can read sectors but speed is very very slow, than forget the alternate method.
you should verify the reading from random position is it same at all places (means very very slow)
try reverse imaging ..
see if it helps
PostPosted: June 15th, 2014, 15:25
Sounds like drive has a firmware issue, hence the slow behavior. It may have other issues as well, but the firmware is simple to check IF the drive allows you to (seems like it should).
PostPosted: June 16th, 2014, 4:21
You need to convert to sata and work your way after that.
PostPosted: June 16th, 2014, 5:14
Good morning !
I do agree !
Either that or using a compatible SATA PCB !
Have a nice week.
PostPosted: June 16th, 2014, 18:12
Hello Friend
I did drive to SATA
Modules are correct.
Heads are correct
I read over the sector
But I can not retrieve any information
What should I do
PostPosted: June 16th, 2014, 19:21
hi
what i doing for initialize the translator.
thanks
PostPosted: June 16th, 2014, 20:07
Spildit wrote:
alimeci wrote:
hi
thanks
I guess that you can try smart hot swap or do head map in RAM if you have DE.
sorry
you can remot my system?
by team viwer
