 Post subject: New versions of some SD Tools are available.
PostPosted: June 4th, 2014, 19:59
SD should be coming on here and saying this themselves.. but anyway, here it is:
HD Doctor for Seagate updated to version 7.0
http://forum.salvationdata.com/viewtopic.php?f=21&t=3785
Added functions:
1. Improved support for 1Tb+ drives partial sector access problem
Improved support for following series
ST2000DL001
ST3000DM001
ST1000DM003
2. 2Tb+ drives aquiring parameters problem, view sector problem solution
3. Busy after ready problem fix
Sometimes Seagate drive can be ready after power on but then the status becomes busy.
One button fix added
Stay with us, more updates will be coming soon.
Please download the software here:
http://down.xlycn.com/download/ST_7.0.0.rar
Newly released version 8.0.5 HD Doctor for WD
http://forum.salvationdata.com/viewtopic.php?f=27&t=3783
Now we have a update for HD Doctor for WD, please download here:
http://down.xlycn.com/HD_Doctor/HD%20Doctor%20for%20WD8.0.5.rar
But obviously SD are so good at data related things they dont have time to learn about simple things such as web links:
 Post subject: Re: New versions of some SD Tools are available.
PostPosted: June 4th, 2014, 21:15
They need to update the Data Compass so I can sell it. I couldn't in good faith sell it to someone with version 10.
PostPosted: June 4th, 2014, 21:40
IMHO optimistic that any update would make it any better! ;)
PostPosted: June 5th, 2014, 2:29
They updated coz they were loosing,,, and loosing alot..
In Biz. you may focus in 1 of 2 targets:
A- Quality
B - Quantity
Just Sell
PostPosted: June 8th, 2014, 6:52
"Fix Busy after Ready" is the new function of Seagate Doctor.
Salvation is not even able to write correctly the script on the button :lol: :lol:
My firmware database:
PostPosted: June 9th, 2014, 23:30
Hi guys, use this "ini" file to fix this problem.
English.ini [7.7 KiB]
Downloaded 1685 times
PostPosted: June 10th, 2014, 7:05
Thank you.
PostPosted: June 18th, 2014, 14:58
Why do i get this error when loading "load from hdd" since i updated to version 7.0?
PostPosted: June 18th, 2014, 15:13
I can't even save mods because when i try it appears appears always this error.
I tried to install again version 6.0 but it doesn't even boot anymore 6.0, i receive "soft. version error".
PostPosted: June 18th, 2014, 16:38
I did some more experiments!
I have found that i receive this error only on 2.5" drives, on 3.5" i don't get EInOutError.
I tried on 2 2.5":
1) Momentus 5400.6 ST9500325AS (Wyatt family, fw 0002BSM1) ----> i backup SA mods of this when i had version 6.0
2) Momentus 7200.4 ST9500420AS (Holliday family, fw 0003LVM1)
on both this 2.5" i get EInOutError in module XJDDL and is impossible to backup SA mods, it's possible only to work in terminal.
:evil: :evil: :evil: :evil: :evil:
DON'T UPDATE TO VERSION 7.0 !!!
PostPosted: June 18th, 2014, 19:34
My suggestion is to not buy the units at all or throw them on a shelf like everyone else.
PostPosted: June 18th, 2014, 20:35
Problem solved!
I installed a new fresh XP 32 bit, now Seagate Doctor is working again properly.
I guess this is a bug of version 7.0, if your operating system is not clean it might interfere with usb Seagate Doctor communication and you will not able to use it.
Also, when you install version 7.0 for the first time, it automatically updates the firmware inside Doctor hardware, then you will not be able to use again version 6.0 or previous versions.
PostPosted: June 18th, 2014, 22:07
LOL at installing an obsolete OS to fix a product. way to go SD...
PostPosted: June 19th, 2014, 7:13
Version 7.0 is not stable and you might have big trouble using it on 2.5" drives, so don't update it.
Unfortunately i already did it and going back to version 6.0 is not possible due to the firmware change inside the tool.
At least I managed to get it working again with a clean XP
:o
PostPosted: June 19th, 2014, 7:42
I never tried HD doctor on recent O.S.
I only worked with it on XP 32 bit.
What i was meaning is that i have installed again XP and now Seagate Doctor is working properly, this means that version 7.0 is not stable enough to work with no clean O.S.
PostPosted: June 24th, 2014, 5:30
I just found out that there are 2 different .exe files for the Seagate HD Doctor 7.0.
HaQue posted the download link of first .exe version which is not good
The second version of 7.0, which worked good for me, you can find here:
down.xlycn.com/download/HD Doctor for Seagate 7.0.rar
P.S.
Please read post of "Nicolaszhou" about the problem:
http://webcache.googleusercontent.com/s ... clnk&gl=it
PostPosted: June 24th, 2014, 11:05
Now i'm sure, the first release of Seagate 7.0 linked by HaQue is not good.
This is the good one:
PostPosted: June 24th, 2014, 13:04
I just linked it from the SD forum when it first came out.
Thanks for fixing it up
BTW if the links don't work due to spaces in the file name then add in %20 in each place there is a space
