 Post subject: WD DRAGFLY1 family : ldr Required :Wd5000AADS - 00S9B0
PostPosted: June 25th, 2014, 2:56
Postby micro999 » Wed Jun 25, 2014 6:49 am
Wd - 500 gb : DRAGFLY1 family
Wd5000AADS - 00S9B0
DCM : HGRNHT2AGN
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 192
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 90.82R
ROM generation.......................... : 90.82R
Link table version...................... : 04.0F.
Consolidated ROM version................ : 00900082
ROM Modules:
Flash ROM dir reading................... : Ok (Active)
Flash ROM dir reading (Ext)............. : Ok
Modules directory address............... : 75 271
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 00900082
Module search process started
Search method........................... : Search by ABA
ABA..................................... : 0
Size in sectors......................... : 184 300
ABA 0 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 1 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 2 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 3 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 4 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 5 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ABA 6 reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
Modules found........................... : 0
Module search process completed
How to access modules ? Can anyone Give me loader file ?
Please help
Regards,
micro
 Post subject: Re: WD DRAGFLY1 family : ldr Required :Wd5000AADS - 00S9B0
PostPosted: June 25th, 2014, 5:58
here you go :idea:
good luck
11.rar [357.26 KiB]
Downloaded 423 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: June 26th, 2014, 13:40
Hi nainesh!
Please report us about your progress
Thanks!
PostPosted: June 27th, 2014, 6:14
Dear Friend ,Tawfeek Mokhtar
Thank you for your kind support .
Upload Loader but HDD gives sound , look like head 0 damaged .
Trying to get SA using head 1 .
Yet NO Data found .
Regards,
Nainesh
PostPosted: June 27th, 2014, 8:28
try hot swap may you can get the data your customer need from the other head. otherwise head swap
Tawfeek Mokhtar
PostPosted: June 27th, 2014, 8:46
If head 0 gives sound, I'll suggest you swap heads first...
Bosse
http://www.rescue-it.se
Users browsing this forum: No registered users and 63 guests
