Post new topic Reply to topic  [ 104 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: WD Mybook Essential 1tb smoke
PostPosted: June 26th, 2014, 12:55
yep, however the pcb might have further issue, i mean that could be also an electrical faulty.
My firmware database:
PostPosted: June 26th, 2014, 13:04
can you test components measures as suggest you fzabkar?
i think this is the way.
them we wil know if PCB is burned or not
(most problably burned)
and them we can test for solve this isue, or maybe donnor PCB needed.
PostPosted: June 26th, 2014, 16:02
Hi Michael Chiklis & hhddrec,
Thx for your comments. Unfortunately my multimeter is too old (built in the 80's) and it can't test the diodes. I ordered a new one today that I ll receive tomorrow. I will let you know if the tvs on the sata pcb are ok or not.
Best regards
0383A
PostPosted: June 27th, 2014, 3:16
I not important if multimeter is old or new one.
For testing Diodes you must test for resistence.
in this way if you test from one way to the other you must get near to 0 and in the other side you must get near infinite
PostPosted: June 27th, 2014, 8:48
Well it is too late I got my new multimeter this morning. and trust me the old one was really old. I even had the user guide, and Google could not find it. One question Where is the + and the - on the TVS diodes?
I don't see the dark line mentioned in the PDF document!
thank you for your assistance
best regards
0383A
PostPosted: June 27th, 2014, 9:55
So here are the value of the TVS diode:
12V TVS diode: 0.028
D3 5V TVS diode: 0.401
Thanks the new multimeter who inform if connect the black and red to the correct +/- or not!
Now I will have to check the ohms on R64 and R67
PostPosted: June 27th, 2014, 10:11
For the R64 & R67 I have to measure the resistance (in Ohms value)
is that correct?
if this is right, here are the values measured:
R64: 0.5
R67: 0.5
Thanks in advance for your feedback.
Best regards
0383A
PostPosted: June 27th, 2014, 11:48
Check that diode again.
PostPosted: June 27th, 2014, 12:01
Hi dick,
Checked again, now I have 0.026
Best regards
0383A
PostPosted: June 27th, 2014, 12:16
Check them both again in both directions using the diode check function if the meter has it.
Write down the results and post them here.
PostPosted: June 27th, 2014, 12:23
Hi dick,
I have taken 2 macro pictures of the 12V TVS diode which I believe shows something not original. There is like a bump on the top of it near GP or GR letters. Here are the pictures:
PostPosted: June 27th, 2014, 12:25
Looks like Diode badly!
PostPosted: June 27th, 2014, 12:27
Yes it has the function, the multimeter is a Velleman DVM4200.
The TVS D3 diode has 0.400 in one way, 0L if I inverse red and black. 0L on the display means wrong way of black/red contacts.
PostPosted: June 27th, 2014, 12:28
Looks like, I ll have to ship both PCBs (the sata one and the usb one) to the Data recovery center for replacement?
PostPosted: June 27th, 2014, 12:33
No!
You can carefully remove the damaged tvs diode. If you are lucky the drive will work.
PostPosted: June 27th, 2014, 12:41
dick wrote:
No!
So, you mean to unsolder the diode. Do I have to replace it with another one?
Should I tell you how my hands were trembling today when I took the 1st measure (like if I do something wrong, I kill everything on the pcb)?
Sometimes My Surname could be Mr Bean. :?
PostPosted: June 27th, 2014, 12:49
Unsoldering bad TVS diodes could work, but usually i prefer to replace them.
If something goes wrong when you will apply again the power supply you might kill head pre-amp without TVS (assuming that pre-amp is not already damaged).
By using new TVS, head pre-amp and pcb circuit should be safer.
If you want i can do this job for you, i have TVS diodes for replacement, i'm in Italy (not far from Switzerland)
PostPosted: June 27th, 2014, 13:28
Hi Michael Chiklis,
thanks for your reply, were are you in Italy?
Kind regards
0383A
PostPosted: June 27th, 2014, 13:53
If the drive works after removing the fused tvs and replacing it then you will need to buy in the usb pcb to be able to decrypt your data. At this moment I think you have a slightly better than even chance of success. Good luck!
PostPosted: June 27th, 2014, 16:00
I have seen many similar cases in WD's forums. The usual result is a shorted 12V TVS diode. If R64 survives, as it has in the OP's case, then the drive is usually OK after removing the diode. You can use flush cutters to do this. You don't actually need to desolder the diode. In fact you may even be able to use finger nail clippers. Just be careful not to lift the copper tracks.
A local TV/AV repair shop should be able to replace the diode. My FAQ lists suitable replacements and sources.
http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
There are ways to repair the bridge PCB without having to purchase any parts, but you would need a little soldering skill and some understanding of electronics.
