 Post subject: exFAT VBR broken
PostPosted: June 27th, 2014, 17:27
Hi there,
One of my external HD's is formatted to exFAT (it's a WD, 2.5'' 1 TB) because I move files around a lot between Ubuntu, Mac and Windows. It seemed a good choice at the time.
However, apparently Macs 'eat' exFAT bootsectors for breakfast and this recently also happened to mine. By using CGSecurity's fantastic tool Testdisk (http://www.cgsecurity.org/wiki/TestDisk) I was able to find out that the Volume Boot Record has been overwritten with zeroes :? As always, the files on this HD are important and I have been too lazy to backup everything :(
Question: Is there a tool (for linux) that can repair exFAT VBR's ? I could obviously download and install the similar fsck_exfat on a Mac, but I was wondering if Ubuntu could fix this for me. I just happen to like Linux better
Thanks, esteemed panel :)
 Post subject: Re: exFAT VBR broken
PostPosted: June 27th, 2014, 21:01
AFAICT, sectors 0 - 11 constitute the Primary VBR while sectors 12 - 23 are the Backup VBR. I have no experience with exFAT, but perhaps the solution may be as simple as using a disc editor to copy the backup sector(s) over the primary ones. Perhaps TestDisk can do this? BTW, it would be advisable to clone your drive first.
Here is one document I found useful:
http://www.sans.org/reading-room/whitep ... stem-33274
PostPosted: June 27th, 2014, 22:52
That's a good article, I read it.. well as much as I could, last year. I advise also to checkout the references at the end of the doc and get even more great papers. In fact I do this on most things I read.
Thanks Franc
 Post subject: [SOLVED] Re: exFAT VBR broken
PostPosted: June 28th, 2014, 5:39
Thanks fzabkar for your reply ! Truly appreciated :D
I did as you were told: copied backup over main superblock. Still couldn't acces the drive :( (not in Linux, nor Mac, nor Win)
I let TestDisk run it again and all of a sudden I could acces the filelist again. I'm now copying everything over to a different external HD and will format this WD afterwards. To another filesystem. No more exFAT for me as long as I have to use Mac... :twisted:
Thanks again !! :good: :good:
[SOLVED]
PostPosted: June 22nd, 2016, 11:33
Sorry to dig out this old thread. I have a situation similar to this.
I have an external storage with 2 x 2TB ( Stardom 2Bay, JBOD mode ) that was working nicely with my Macmini .
Somehow since last week the disk is not readable anymore. I got the message that " The disk you inserted was not readable by this computer " and it asked to "Initialize", "Ignore" or "" Eject".
OS is the newest El Capitan (10.11.5) and I've tried other enclosure and docking station and all saw the same message.
I also tried multiple computers (MBAs, MB, PC Win 7) and got the same issue.
I then started trying to repair it on OSX Terminal: "diskutil list" showed me the disk is now disk3 without partition.
So I did this first: sudo diskutil verifyVolume /dev/disk3 and I got the error message: " Error starting file system verification for disk3: Unrecognized file system (-69846)" .
Then I used "sudo fsck_exfat -d /dev/disk3".
Now I got the message:
"Opening /dev/rdisk3 ** Checking volume. ** Checking main boot region. fsck_exfat: Invalid jump or signature Main boot region is invalid. Trying alternate boot region. ** Checking alternate boot region. fsck_exfat: Invalid jump or signature Alternate boot region is invalid. ** The volume could not be verified completely."
I then looked into TestDisk in Linux.
http://imgur.com/a/HoWrJ
The picture was taken around 15% but I did complete the analysis.
But it seems like not recoverable.
I am trying to scan it with R-studio for data recovery now and found that the label is 00000000000000000000. The scan is still ongoing since it is doing slowly. But I think this might be related to your post regarding the broken VBR. However I don't understand how you exactly fixed the VBR.
Thanks for your suggestions.
