 Post subject: where to buy a 2013 macbook air pcie ssd adapter
PostPosted: July 3rd, 2014, 15:57
Need to recover data from 2013 apple macbook air 13 inch pcie ssd, does anyone know where to buy the special adapter to connect to either sata or usb?
 Post subject: Re: where to buy a 2013 macbook air pcie ssd adapter
PostPosted: July 3rd, 2014, 16:03
They don't exist…yet. As far as I know they are under construction and should be for sale in two weeks or so.
Until then you can use another air to extract the files.
Bosse
http://www.rescue-it.se
PostPosted: July 3rd, 2014, 16:25
I can recover these drives, if you want to outsource to my lab.
PostPosted: July 3rd, 2014, 17:33
Why not make a passive adapter to connect it to a regular PCIe slot? Just cut the fingers off a cheap PCIe card. It doesn't even need to be working.
PostPosted: July 4th, 2014, 6:59
But what is the problem?
can you explain us?
maybe not neded an adapter!
PostPosted: August 21st, 2014, 4:38
I have done this now... sort of .. with a PCI-E prototyping board..
Works great! :)
