 Post subject: Recovering data from possibly corrupted Truecrypt volume
PostPosted: July 4th, 2014, 3:22
I have an external hard drive (no system files on it) which has been encrypted using truecrypt. Suddenly today when i tried to mount the hard drive, I got the following error:
Incorrect password or not a truecrypt volume
So I tried to mount it using mount options and choosing use backup embedded headers embedded in volume if available option. When I do that the hard drive mounts but I am not able to access any files in the drive.
I get the following error when I click on the drive to open it:
You need to format the disk drive in J: before using it
How do I recover my files? This is very important and urgent. Your help will be greatly appreciated
PS: I am using windows 7 64bit
 Post subject: Re: Recovering data from possibly corrupted Truecrypt volume
PostPosted: July 4th, 2014, 3:39
This article Data Recovery from Various File Container Formats and Encrypted Disks may help.
PostPosted: July 4th, 2014, 4:28
Do you have a copy of the Truecrypt rescue disk or the iso you created?
PostPosted: July 4th, 2014, 5:07
Unfortunately I have misplaced my rescue disk
PostPosted: July 4th, 2014, 6:08
Was it a single partition?
NTFS?
Have you cloned/imaged the drive?
Here are my steps I wrote down when I had a look at recovering a deleted partition with Truecrypt I know its not the exact same issue your describing but it might be helpful if sector0 has got corrupted.
I was using Winhex to do this.
Deleted Truecrypt Partition Repair.docx [30.05 KiB]
Downloaded 603 times
Loki
PostPosted: July 4th, 2014, 6:09
When the drive mounts as drive "j" you could copy the partition to another drive as an image file. Then run recovery software on the image. Dmde would be a good start to make the 'j_partition.img' file. Then you could open it with the Dmde software and see what might be available. How big is the drive/partition?
PostPosted: July 4th, 2014, 6:38
@Loki
Its a single partition
It is NTFS
No, Hvaen't cloned or imaged the partition
Also looking at your instruction sheet :
[*]How do i action step 3 ? Actually can you help me out with points 3-11 on that list. I haven't used winHex before.
Here is the screen shot when i load the drive in winHex :
@dick
I will try abd do that if recovery method suggested by @loki doesn't work. Also its 1.8TB (massive)
PostPosted: July 4th, 2014, 7:41
You could just run Dmde and point it towards the external drive and "j" partition to see what partition info is available. I would certainly do that! If you see your partition you can open the volume and then recover a couple of files to a second drive and check them.
Also as you are considering making changes to the partition you MUST backup the partition info!
PostPosted: July 4th, 2014, 7:55
@dick How do i do that. here is what i see when I open j drive in dmde:
PostPosted: July 4th, 2014, 10:18
"How do I recover my files? This is very important and urgent"
Firstly you should always clone or image the device if possible as if you make a mistake you ruin your chances of recovery or make it more expensive to get a recovery from a pro.
DIY comes with risks & not knowing your limits also puts your data at risk.
If your not sure about something, try & practice & research it using another device
If the data is very important as you say then if I were you I wouldn't risk DIY without an Image backup.
Loki
