 Post subject: How to open enclosure from LaCie P'2930 Porsche Design ?
PostPosted: July 7th, 2014, 7:51
Hi guys,
Having to open the casing of an Lacie P9230 3TB hard drive, I wonder if one of you already has done it?
Removing the rubbers below, gives access to the four screws that fix the hard drive, but the housing itself seems clipped.
I don't want to damage the plastic nor the metal of the housing.
Hence, I wonder at which precise locations should I put the screwdrivers to unclip it.
I can see two rectangular holes on the front of the enclosure.
Should I push here first ?
Thank you.
 Post subject: Re: How to open enclosure from LaCie P'2930 Porsche Design ?
PostPosted: July 7th, 2014, 13:30
SOSdonnees wrote:
Hi guys,
Thank you.
Solved. It suffice to press with a small flat screwdriver in the two small rectangurar holes on the front of the housing. Then, the metallic cover can easily removed.
Users browsing this forum: No registered users and 73 guests
