 Post subject: HELP!!! HD Samsung 250GB
PostPosted: July 7th, 2014, 20:35
Banned User
Hello guys! Need firmware Samsung HD Model: HD250HJ P/N: HD250HJ/SRA Rev. A 2008.03
 Post subject: Re: HELP!!! HD Samsung 250GB
PostPosted: July 8th, 2014, 9:58
Sorry, i have not this FW
PostPosted: July 8th, 2014, 10:07
what is the original problem ?
can you post terminal log ?
Data Recovery Pakistan
PostPosted: July 8th, 2014, 10:38
What makes you think it's firmware problem?
And also, what do you propose doing with said firmware if you're given it?
PostPosted: July 12th, 2014, 0:32
Banned User
The HD in question is not being detected in the BIOS, I've tested all components of the PCB, when this happens the problem is in the firmware ROM PCB that due to some electrical problem blew out the basic program HDD operation.
PostPosted: July 13th, 2014, 14:19
provide more details;
does drive spin up with original PCB ?
If yes what is the behaviour of drive ? e.g clicking or busy ?
what equipment/tools you have ?
If problem is with pcb, you can find a compatible pcb and transfer the ROM if it has one and you should be able to get the data, assuming there is no physical problem with the disk.
Users browsing this forum: Majestic-12 [Bot] and 59 guests
