 Post subject: Shorting PIN for 100687658
PostPosted: January 18th, 2014, 4:13
Terminal locks on this one.
which pin to short to get access to Terminal please for the PCB?
100687658
This is the PIC http://www.drivestar.biz/seagate-100687658-p-2804.html
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: Shorting PIN for 100687658
PostPosted: January 18th, 2014, 5:18
If you are referring to shorting the read channel ...
Tip: How to identify the Read Channel test points:
http://malthus.zapto.org/viewtopic.php?f=24&t=123
PostPosted: July 11th, 2014, 18:29
Hi Shahij,
I am facing exactly the same problem.
Have you managed to identify the pins for read channel?
Thank you in advance for your prompt reply!
PostPosted: July 14th, 2014, 4:00
100687658
Not good pic! can you send higth resolution one?
PostPosted: July 14th, 2014, 4:28
http://ep.yimg.com/ay/yhst-444636922352 ... 7658-4.gif
Pins 12 - 18 of J4 are the read/write channel differential pairs. Measure the voltages at each of the pins to determine which is which. Do this with the board removed from the drive. There is a row of 4 corresponding through-holes on the other side of the PCB.
Users browsing this forum: No registered users and 99 guests
