Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Need a little help with a Seagate Barracuda 7200 11 1.5T
PostPosted: July 10th, 2014, 17:08
The "v" indicates the cathode, ie the striped end.
+12V o-------+-------o
            _|_
            /_\
  Gnd o------+-------o
PostPosted: July 14th, 2014, 3:13
Hello :)
as promised, here is an update about the HDD.
I couldn't find a diode for replacement, so i tried using a wire, i removed the diode and added a wire as a replacement, but appearently something else is broken, because the HDD doesn't power on, no spinning, nothing.
I guess it's gone for good
PostPosted: July 14th, 2014, 3:20
Why would you replace a short circuit with another short circuit?
Look at my diagram. What do you think would happen if you were to connect a wire between +12V and ground?
PostPosted: July 14th, 2014, 3:39
mhhh i screwed :(
Users browsing this forum: No registered users and 214 guests
