 Post subject: ST500DM002....Cannot access the terminal
PostPosted: July 16th, 2014, 4:45
I have 2 Seagate Sata ST500DM002 hdd, both the hdd spins normal but cannot access the terminal. Even I try to short pin point also ....it shows the following message as show below after shorting :-
Boot 0x10M
Spin Up[0x00000000][0x00000000]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
FAIL Servo Op=0155 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00025CB4][0x00025CB4]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
FAIL Servo Op=0055 Resp=0007
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x0000B319][0x0000B319]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWYWYWWMMMMMM
ResponseFrame 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 000Ax[0x00030FCD][0x00030FCD]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWWMMMMMM
Any help appreciated....
 Post subject: Re: ST500DM002....Cannot access the terminal
PostPosted: July 16th, 2014, 5:40
Can you report us more info about HDD.
FW, ROM, PCB info too
symptomps about HDD, clicking sounds, the drive starts spining, and oter data.
Maybe posible that you can send HDD sticker pics and PCB both sides pics.
Data is important? or maybe not important?
thanks
PostPosted: July 16th, 2014, 8:50
High chance it is a problem with the terminal set up. What is your hardware and software terminal set up?
PostPosted: July 17th, 2014, 4:41
Hd spin normally, no strange sound only terminal is not accessable, as we are using PC3K
I contact to ACE support but they said, short the pin point.....still hdd is not getting ready
Data is important.
Mdl=ST500DM002
FW=KC45
PCB No=100535704 REV C
PostPosted: July 17th, 2014, 5:00
Are you sure that you terminal is in good condition?
test it with other working similar HDD
PostPosted: July 17th, 2014, 5:07
I have checked with other working hdd, terminal is properly working.....
Hdd have some strange problem and I have 2 of them.....
PostPosted: July 17th, 2014, 7:23
did hard drive report his model and capacity correctly in PC3K ?
Data Recovery Pakistan
PostPosted: July 17th, 2014, 7:24
Are you sure you are shorting the correct points at the correct time?
Data Recovery Cape Town
PostPosted: July 17th, 2014, 8:04
No hdd stay only busy and I am shorting right points......
PostPosted: July 17th, 2014, 15:48
This takes some finesse. Wait for the second "spin-up" message in terminal then short the points. Keep shorting the points for a few seconds; remove short. Terminal output will continue for a few minutes and then stop. Drive should then be ready. These drives do not spin down during the procedure but they will come ready if your technique is good. Patience.
