Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: hard drive reads in short bursts
PostPosted: August 2nd, 2014, 15:44
greetings. i have a drive that reads in short bursts. the only way i can better describe is running a scan in MHDD, the drive reads for about 1 - 2 seconds then stops for another 2 seconds then starts reading again. any known reason why it would do this? i should also mention getting over 700 UNC readings.
drive is WD10EZEX-60ZF5A0
 Post subject: Re: hard drive reads in short bursts
PostPosted: August 2nd, 2014, 15:49
Drive has bad sector + fw issue (probably Re-Lo list).
Maybe also weak head?
My firmware database:
PostPosted: August 2nd, 2014, 15:55
sorry i should have mentioned i don't know much about data recovery, i am here to learn really. what do you mean by "fw issue"? firmware issue? and also Re-Lo list?
PostPosted: August 2nd, 2014, 15:59
Yes fw means firmware.
Re-Lo list is a firmware module, very often this module gets corrupt on WD drives if there are bad sectors, if Re-Lo list is corrupt then you will read sectors very slowly.
You need pro tools to fix this, example PC3000, HD Doctor or other good tools as Sediv or WDR.
PostPosted: August 2nd, 2014, 16:09
okay. so i have a couple torx screw drivers and really just need a reason to tear this drive apart. what would you suggest to me for getting the most learning experience out of this drive. are there any free tools to diagnose the problem further? or should i just go nuts and open the thing?
PostPosted: August 2nd, 2014, 17:38
If you need to recover data i suggest you to send the drive to a pro.
If you don't need data and you just want to play with it then you can begin using this tools:
Sediv (demo): http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar
WDR demo: viewtopic.php?t=20176&start=
this tools can damage your drive, even demo version, so be carefull
With sediv demo you can read ROM and SA firmware (example Re-Lo list is module 32), with WDR demo you can check heads and rebuild translators.
watch some videos:
read also this:
http://malthus.zapto.org/viewtopic.php?f=86&t=848
http://malthus.zapto.org/viewtopic.php?f=84&t=31
http://malthus.zapto.org/viewtopic.php?f=32&t=84
http://www.sediv.net/forums/
viewtopic.php?f=16&t=6562
http://www.southbit.co.za/inside-a-hard-drive/
i don't suggest to open the drive now, first begin to understand how firmware works by using sediv.
PostPosted: August 3rd, 2014, 14:33
by "reading" the re-lo list, is this some sort of check for errors in it? how exactly would i know if it is corrupted? can the demo version of SeDiv do this? and if isn't too much trouble, can you explain how to verify integrity of re-lo list?
i already know how to load the drive into SeDiv. after this however i am overwhelmed by a myriad of buttons.
PostPosted: August 4th, 2014, 15:03
Sediv in versione demo è in grado di effettuare il backup del firmware degli hdd WD.
Premi su "Read ALL" nella parte destra di Sediv (è scritto in rosso).
Quel pulsante serve per effettuare il backup della ROM + gli adaptives + il firmware interno (SA) con un solo clic.
Prima però seleziona la cartella in cui vuoi salvare i files di sediv andando sul menù "Program" - "Settings", premi "view" per selezionare la cartella di destinazione, poi "Save".
La Re-Lo list è il modulo 0032, per controllarlo dovrai aprirlo con un editor esadecimale, ad esempio col programma Hex Workshop (a pagamento) o con HxD (freeware)
http://mh-nexus.de/en/hxd/
Ovviamente se non sai come dovrebbe essere una Re-Lo list in buono stato non potrai avere un parametro di confronto per capire come è messa, quindi se vuoi puoi postare il modulo (o se vuoi l'intero firmware) sul forum così che qualcuno possa esaminarlo.
Altri controlli che puoi fare è la visualizzazione dello stato SMART (tasto SMART) e delle liste dei difetti (tasto Defect List di colore blu).
PostPosted: August 5th, 2014, 2:05
Module 0032 is okay but i get a CRC error on module 0121.
Version ROM FW: 002500B2
Version  SA FW: 002500B3
Version FW Different!
Action: Read APB................................................. OK!
Action: Read Drive Table......................................... OK!
Action: Read Zone Table.......................................... OK!
Action: Get User Cyl............................................. OK!
Action: Read Resident file: 000B................................. OK! (Not Active)
Action: Read Resident file: 020B................................. OK! (Active)
Action: Read Flash............................................... OK!
Action: Read Resident file: 0001................................. OK!
Save Data(Read Flash Module: 01) OK
Action: Read Resident file: 000A................................. OK!
Save Data(Read Flash Module: 0A) OK
Save Data(Read Flash Module: 0B) OK
Save Data(Read Flash Module: 20B) OK
Action: Read Resident file: 0030................................. OK!
Save Data(Read Flash Module: 30) OK
Action: Read Resident file: 0047................................. OK!
Save Data(Read Flash Module: 47) OK
Action: Read Resident file: 000D................................. OK!
Save Data(Read Flash Module: 0D) OK
Action: Read Resident file: 004F................................. OK!
Save Data(Read Flash Module: 4F) OK
--------------------------------- Task Begin --------------------------------
Read Resident File Dir
Number of File Entries = 386
------------------------------- Task Completed ------------------------------
01.50.12
Module 0062    1      520E48E4    520E48E4    CRC: OK
Module 0035    10     46FC2A11    46FC2A11    CRC: OK
Module 8010    5      7338F55E    7338F55E    CRC: OK
Module 802C    3      773AF542    773AF542    CRC: OK
Module 8035    16     4546EF9B    4546EF9B    CRC: OK
Module 8038    2      793BF536    793BF536    CRC: OK
Module 803C    2      793BF532    793BF532    CRC: OK
Module 8016    5      7338F558    7338F558    CRC: OK
Module 801D    33     3B1CF551    3B1CF551    CRC: OK
Module 8044    2      F940A6E0    F940A6E0    CRC: OK
Module 8031    4      7539F53D    7539F53D    CRC: OK
Module 8062    13     6330F50C    6330F50C    CRC: OK
Module 8063    13     6330F50B    6330F50B    CRC: OK
Module 8041    2      793BF52D    793BF52D    CRC: OK
Module 8042    2      793BF52C    793BF52C    CRC: OK
Module 800E    5      7338F560    7338F560    CRC: OK
Module 802D    65     FAFCF541    FAFCF541    CRC: OK
Module 8019    5      7338F555    7338F555    CRC: OK
Module 802F    8      6D35F53F    6D35F53F    CRC: OK
Module 8034    13     8EB5A1C1    8EB5A1C1    CRC: OK
Module 802E    8      6D35F540    6D35F540    CRC: OK
Module 8032    8      6D35F53C    6D35F53C    CRC: OK
Module 8017    5      4AF2EEA1    4AF2EEA1    CRC: OK
Module 8002    2      A49BEE15    A49BEE15    CRC: OK
Module 800B    2      A49BEE0C    A49BEE0C    CRC: OK
Module 8005    2      1EDB5A8A    1EDB5A8A    CRC: OK
Module 8020    4      7539F54E    7539F54E    CRC: OK
Module 8046    2      952ADC27    952ADC27    CRC: OK
Module 8045    2      793BF529    793BF529    CRC: OK
Module 8027    2      793BF547    793BF547    CRC: OK
Module 8014    1      733CF55A    733CF55A    CRC: OK
Module 801C    2      793BF552    793BF552    CRC: OK
Module 8023    3      DF29DEAF    DF29DEAF    CRC: OK
Module 801F    2      793BF54F    793BF54F    CRC: OK
Module 803A    2      793BF534    793BF534    CRC: OK
Module 803E    2      793BF530    793BF530    CRC: OK
Module 8012    5      B717528A    B717528A    CRC: OK
Module 8026    13     555B251A    555B251A    CRC: OK
Module 802B    5      7338F543    7338F543    CRC: OK
Module 8029    2      793BF545    793BF545    CRC: OK
Module 802A    2      793BF544    793BF544    CRC: OK
Module 8037    2      793BF537    793BF537    CRC: OK
Module 803B    2      793BF533    793BF533    CRC: OK
Module 800F    5      AD6B97BE    AD6B97BE    CRC: OK
Module 800A    2      9C2AE059    9C2AE059    CRC: OK
Module 8025    2      9C2AE03E    9C2AE03E    CRC: OK
Module 8009    2      9C2AE05A    9C2AE05A    CRC: OK
Module 800C    2      CED7ABAA    CED7ABAA    CRC: OK
Module 8006    2      9B2AE25D    9B2AE25D    CRC: OK
Module 8018    2      793BF556    793BF556    CRC: OK
Module 800D    5      8980EA91    8980EA91    CRC: OK
Module 8008    2      F93A37A9    F93A37A9    CRC: OK
Module 8024    2      793BF54A    793BF54A    CRC: OK
Module 8015    2      9D2ADE4E    9D2ADE4E    CRC: OK
Module 8007    2      793BF567    793BF567    CRC: OK
Module 8065    33     3B1CF509    3B1CF509    CRC: OK
Module 801A    5      6E294ADB    6E294ADB    CRC: OK
Module 8030    2      793BF53E    793BF53E    CRC: OK
Module 801E    101    F2050A2D    F2050A2D    CRC: OK
Module 8001    2      793BF56D    793BF56D    CRC: OK
Module 8022    5      9627E041    9627E041    CRC: OK
Module 8064    5      7338F50A    7338F50A    CRC: OK
Module 8049    13     6330F525    6330F525    CRC: OK
Module 805D    5      7338F511    7338F511    CRC: OK
Module 805E    13     6330F510    6330F510    CRC: OK
Module 805F    16     5D2DF50F    5D2DF50F    CRC: OK
Module 8060    2      793BF50E    793BF50E    CRC: OK
Module 8061    2      793BF50D    793BF50D    CRC: OK
Module 8011    5      7338F55D    7338F55D    CRC: OK
Module 803F    2      793BF52F    793BF52F    CRC: OK
Module 8040    2      793BF52E    793BF52E    CRC: OK
Module 8033    13     6330F53B    6330F53B    CRC: OK
Module 8043    2      A0588249    A0588249    CRC: OK
Module 8000    2      A4877657    A4877657    CRC: OK
Module 8021    3      2D5FCF75    2D5FCF75    CRC: OK
Module 8FFC    1      7B3CE572    7B3CE572    CRC: OK
Module 8FFD    8      6D35E571    6D35E571    CRC: OK
Module 8FFE    16     5D2DE570    5D2DE570    CRC: OK
Module 8047    33     3B1CF527    3B1CF527    CRC: OK
Module 8048    13     7CD23E0D    7CD23E0D    CRC: OK
Module 8004    3      0447D8C1    0447D8C1    CRC: OK
Module 8003    3      363CC700    363CC700    CRC: OK
Module 8028    3      363CC8DB    363CC8DB    CRC: OK
Module 8039    2      793BF535    793BF535    CRC: OK
Module 803D    2      793BF531    793BF531    CRC: OK
Module 8036    16     5D2DF538    5D2DF538    CRC: OK
Module 801B    33     3B1CF553    3B1CF553    CRC: OK
Module 8013    5      7338F55B    7338F55B    CRC: OK
Module 804C    5      7338F522    7338F522    CRC: OK
Module 804D    13     6330F521    6330F521    CRC: OK
Module 804E    100    B4D9F520    B4D9F520    CRC: OK
Module 804F    3      773AF51F    773AF51F    CRC: OK
Module 804A    5      7338F524    7338F524    CRC: OK
Module 804B    13     6330F523    6330F523    CRC: OK
Module 8050    5      7338F51E    7338F51E    CRC: OK
Module 8051    13     6330F51D    6330F51D    CRC: OK
Module 8052    16     5D2DF51C    5D2DF51C    CRC: OK
Module 8053    5      7338F51B    7338F51B    CRC: OK
Module 8054    13     6330F51A    6330F51A    CRC: OK
Module 8055    5      7338F519    7338F519    CRC: OK
Module 8056    13     6330F518    6330F518    CRC: OK
Module 8057    5      7338F517    7338F517    CRC: OK
Module 8058    13     6330F516    6330F516    CRC: OK
Module 8059    5      7338F515    7338F515    CRC: OK
Module 805A    13     6330F514    6330F514    CRC: OK
Module 805B    16     5D2DF513    5D2DF513    CRC: OK
Module 805C    2      793BF512    793BF512    CRC: OK
Module 8066    2      793BF508    793BF508    CRC: OK
Module 8067    5      7338F507    7338F507    CRC: OK
Module 8068    13     6330F506    6330F506    CRC: OK
Module 8069    15     E6ED4EE3    E6ED4EE3    CRC: OK
Module 806A    3      DCD86967    DCD86967    CRC: OK
Module 806C    4      7539F502    7539F502    CRC: OK
Module 806D    11     6732F501    6732F501    CRC: OK
Module 806E    33     3B1CF500    3B1CF500    CRC: OK
Module 290B    505    44BDF46F    44BDF46F    CRC: OK
Module 0091    8      38A79A5C    38A79A5C    CRC: OK
Module 290C    1      4CC50121    4CC50121    CRC: OK
Module 00AE    297    ED97C242    ED97C242    CRC: OK
Module 290F    279    4139733B    4139733B    CRC: OK
Module 2916    244    B37E0C6C    B37E0C6C    CRC: OK
Module 1000    27     6DFD6842    6DFD6842    CRC: OK
Module 00B1    30     C20E90C1    C20E90C1    CRC: OK
Module 00B2    37     71510BDD    71510BDD    CRC: OK
Module 1001    25     636E3F99    636E3F99    CRC: OK
Module 1002    35     8F599017    8F599017    CRC: OK
Module 1009    32     AA5B2F91    AA5B2F91    CRC: OK
Module 100A    36     D7D3BB0C    D7D3BB0C    CRC: OK
Module 1003    36     99AB2FF2    99AB2FF2    CRC: OK
Module 100C    24     7265DAC4    7265DAC4    CRC: OK
Module 1005    30     95EA5552    95EA5552    CRC: OK
Module 100F    28     E61760A0    E61760A0    CRC: OK
Module 1004    40     8493D20A    8493D20A    CRC: OK
Module 1007    24     CF2B2C5B    CF2B2C5B    CRC: OK
Module 100B    22     9042F297    9042F297    CRC: OK
Module 100E    22     CF124EBA    CF124EBA    CRC: OK
Module 1008    33     A53B5DF1    A53B5DF1    CRC: OK
Module 1010    22     252D9B2E    252D9B2E    CRC: OK
Module 2B00    292    AF55AECE    AF55AECE    CRC: OK
Module 0033    1260   BE4746B4    BE4746B4    CRC: OK
Module 0031    820    D6D9FB9D    D6D9FB9D    CRC: OK
Module 000C    12     1FDCE986    1FDCE986    CRC: OK
Module 0034    48     4B813059    4B813059    CRC: OK
Module 0032    60     A2236E18    A2236E18    CRC: OK
Module 0036    8      4F35973C    4F35973C    CRC: OK
Module 0029    11     3D181B30    3D181B30    CRC: OK
Module 0040    459    4B6EB761    4B6EB761    CRC: OK
Module 0041    459    676FB40F    676FB40F    CRC: OK
Module 0042    459    676FB40E    676FB40E    CRC: OK
Module 0043    459    676FB40D    676FB40D    CRC: OK
Module 004E    1265   056BC13A    056BC13A    CRC: OK
Module 0049    4      E5F34FBA    E5F34FBA    CRC: OK
Module 004A    9      74B9C503    74B9C503    CRC: OK
Module 004D    1      520E48F9    520E48F9    CRC: OK
Module 0003    334    D344AB14    D344AB14    CRC: OK
Module 0025    257    65EB83D3    65EB83D3    CRC: OK
Module 0026    129    4A7A4920    4A7A4920    CRC: OK
Module 0038    257    49FA490E    49FA490E    CRC: OK
Module 0039    17     4AEA490D    4AEA490D    CRC: OK
Module 0037    2      001AF71B    001AF71B    CRC: OK
Module 006B    4      9950AE63    9950AE63    CRC: OK
Module 003A    12     A354EA36    A354EA36    CRC: OK
Module 0028    16     4F444253    4F444253    CRC: OK
Module 003B    16     4F7548A1    4F7548A1    CRC: OK
Module 003C    16     4F44423F    4F44423F    CRC: OK
Module 003D    16     4F44423E    4F44423E    CRC: OK
Module 003E    16     4F44423D    4F44423D    CRC: OK
Module 003F    16     4F44423C    4F44423C    CRC: OK
Module 006F    1472   49B6FECC    255C7D40    CRC: OK
Module 0116    6      4AF54830    4AF54830    CRC: OK
Module 0118    32     9869CE50    9869CE50    CRC: OK
Module 0119    5      83367758    83367758    CRC: OK
Module 0068    155    62165541    62165541    CRC: OK
Module 0069    155    67FA619D    67FA619D    CRC: OK
Module 006A    155    67FA619C    67FA619C    CRC: OK
Module 0120    889    7EC32AC7    7EC32AC7    CRC: OK
Module 0132    32     4F91C983    4F91C983    CRC: OK
Module 0149    85     9FC9332D    9FC9332D    CRC: OK
Module 0148    2      D087FD59    D087FD59    CRC: OK
Module 0175    9      520647CF    520647CF    CRC: OK
Module 0004    28166  AB1CEC00    AB1CEC00    CRC: OK
Module 0005    28166  C3E2DE3A    C3E2DE3A    CRC: OK
Module 3700    286    F1267EF2    F1267EF2    CRC: OK
Module 00DE    297    3F8099B4    3F8099B4    CRC: OK
Module 00B6    287    16B8759A    16B8759A    CRC: OK
Module 00D5    305    5C3007E9    5C3007E9    CRC: OK
Module 34D5    316    51F72838    51F72838    CRC: OK
Module 3426    212    9B549764    9B549764    CRC: OK
Module 3424    209    F2D6E5D4    F2D6E5D4    CRC: OK
Module 3425    223    05A101D9    05A101D9    CRC: OK
Module 3431    258    F5C2FAF5    F5C2FAF5    CRC: OK
Module 3430    254    C86F3B05    C86F3B05    CRC: OK
Module 3411    182    EEA22D34    EEA22D34    CRC: OK
Module 00D1    323    7EFE0588    7EFE0588    CRC: OK
Module 3513    313    E7104FA0    E7104FA0    CRC: OK
Module 34D1    309    425711CD    425711CD    CRC: OK
Module 34D2    318    C0B25876    C0B25876    CRC: OK
Module 34D3    320    ECCE5176    ECCE5176    CRC: OK
Module 34D4    329    3FCF4811    3FCF4811    CRC: OK
Module 34D6    334    21D0CDB4    21D0CDB4    CRC: OK
Module 00DB    296    42838061    42838061    CRC: OK
Module 00DF    315    7522761B    7522761B    CRC: OK
Module 00DD    283    3FBEFF19    3FBEFF19    CRC: OK
Module 3309    193    850C5F54    850C5F54    CRC: OK
Module 3413    255    299390A9    299390A9    CRC: OK
Module 3429    183    6313DB62    6313DB62    CRC: OK
Module 3402    291    E50E1330    E50E1330    CRC: OK
Module 00D7    285    3956D352    3956D352    CRC: OK
Module 00D2    201    95C47D74    95C47D74    CRC: OK
Module 3300    202    376B791B    376B791B    CRC: OK
Module 3301    227    9843B3C7    9843B3C7    CRC: OK
Module 3307    219    A03E26B5    A03E26B5    CRC: OK
Module 3303    184    D0CDA801    D0CDA801    CRC: OK
Module 3500    244    F025C62B    F025C62B    CRC: OK
Module 00BB    223    625EC1A8    625EC1A8    CRC: OK
Module 3400    259    ACA4BBB0    ACA4BBB0    CRC: OK
Module 3407    245    B90B918E    B90B918E    CRC: OK
Module 3405    248    FF6B4338    FF6B4338    CRC: OK
Module 00D9    282    8869D894    8869D894    CRC: OK
Module 00D4    198    31065318    31065318    CRC: OK
Module 3305    186    31712E83    31712E83    CRC: OK
Module 00DC    215    2B4EEDFE    2B4EEDFE    CRC: OK
Module 00D0    218    A6075E6D    A6075E6D    CRC: OK
Module 00D3    180    D5E3A24C    D5E3A24C    CRC: OK
Module 00F7    279    D3B3BDDE    D3B3BDDE    CRC: OK
Module 00BA    256    3EC787E2    3EC787E2    CRC: OK
Module 3406    244    7ED45F97    7ED45F97    CRC: OK
Module 00B9    252    53ECECFA    53ECECFA    CRC: OK
Module 00BC    245    4BF61DF7    4BF61DF7    CRC: OK
Module 3417    251    BC53C902    BC53C902    CRC: OK
Module 00D8    184    C0F4BA77    C0F4BA77    CRC: OK
Module 00BD    314    429EE856    429EE856    CRC: OK
Module 00BE    27     42992D1B    42992D1B    CRC: OK
Module 3401    242    94AFECA8    94AFECA8    CRC: OK
Module 3302    212    0011E34A    0011E34A    CRC: OK
Module 3304    200    EA63CEA6    EA63CEA6    CRC: OK
Module 3501    250    49255299    49255299    CRC: OK
Module 3502    243    F663B801    F663B801    CRC: OK
Module 3416    201    0B5A0314    0B5A0314    CRC: OK
Module 3F01    8      3702F045    3702F045    CRC: OK
Module 00B8    2      4300A695    4300A695    CRC: OK
Module 00BF    8      37032E87    37032E87    CRC: OK
Module 00E6    175    462C4C97    462C4C97    CRC: OK
Module 00E7    32     9A62DBD8    9A62DBD8    CRC: OK
Module 34E7    32     06EAFA5F    06EAFA5F    CRC: OK
Module 3802    2      4308F744    4308F744    CRC: OK
Module 3801    32     D304BFEA    D304BFEA    CRC: OK
Module 3415    518    E8367315    E8367315    CRC: OK
Module 3418    211    B7ECC2DD    B7ECC2DD    CRC: OK
Module 3423    217    2BBF92AA    2BBF92AA    CRC: OK
Module 3422    221    A9BBBFB4    A9BBBFB4    CRC: OK
Module 3511    182    F4C3B14A    F4C3B14A    CRC: OK
Module 3421    210    AA759231    AA759231    CRC: OK
Module 3503    243    11067B73    11067B73    CRC: OK
Module 3F00    65     87CEE24F    87CEE24F    CRC: OK
Module 3504    244    17109CF0    17109CF0    CRC: OK
Module 3408    286    E3CF722C    E3CF722C    CRC: OK
Module 00C4    513    55EEC452    55EEC452    CRC: OK
Module 00A2    143    E0C30E37    E0C30E37    CRC: OK
Module 00C5    507    20262842    20262842    CRC: OK
Module 2900    115    40EC47C5    40EC47C5    CRC: OK
Module 2F00    449    E06D934F    E06D934F    CRC: OK
Module 290E    435    7D109669    7D109669    CRC: OK
Module 009F    48     1D693AE5    1D693AE5    CRC: OK
Module 2902    438    A044E062    A044E062    CRC: OK
Module 2820    285    0090211A    0090211A    CRC: OK
Module 2051    56     F42E3138    F42E3138    CRC: OK
Module 2050    56     E6C6865A    E6C6865A    CRC: OK
Module 2021    80     B19A134A    B19A134A    CRC: OK
Module 2020    80     B19A134B    B19A134B    CRC: OK
Module 1121    128    DF7511B9    DF7511B9    CRC: OK
Module 1104    128    4E9AA2E4    4E9AA2E4    CRC: OK
Module 1101    128    2252E603    2252E603    CRC: OK
Module 80FE    32     273B5FB6    273B5FB6    CRC: OK
Module 009A    75     2287F66A    2287F66A    CRC: OK
Module 00A0    64     FFAB1276    FFAB1276    CRC: OK
Module 0096    122    8B78A93B    8B78A93B    CRC: OK
Module 012D    800    FCCB11E9    FCCB11E9    CRC: OK
Module 012A    8      FFE311EC    FFE311EC    CRC: OK
Module 0128    129    FF6A11EE    FF6A11EE    CRC: OK
Module 0121    8193   52659D9C    F633993F    CRC: Error
Module 002E    801    0EEDF051    0EEDF051    CRC: OK
Module 002D    800    FCCB12E9    FCCB12E9    CRC: OK
Module 806B    21     47A27007    47A27007    CRC: OK
Module 806F    10     FFE092A7    FFE092A7    CRC: OK
Module 80FC    2      9A63BBDD    9A63BBDD    CRC: OK
Module 009C    1      FF534499    FF534499    CRC: OK
Module 00CF    15     8055247F    8055247F    CRC: OK
Module 0099    12     FFDF127D    FFDF127D    CRC: OK
Module 3C00    32     FFCAD716    FFCAD716    CRC: OK
Module 00FA    256    FEEB121C    FEEB121C    CRC: OK
Module 009E    5      8C8CDEA5    8C8CDEA5    CRC: OK
Module 00C1    1      CD027806    CD027806    CRC: OK
Module 3E00    2      451AE7ED    451AE7ED    CRC: OK
Module 00FC    4      FFE7121A    FFE7121A    CRC: OK
Module 1100    16     71B3F67E    71B3F67E    CRC: OK
Module 00AF    1000   17294020    17294020    CRC: OK
Module 0098    24     7DB2CF6A    7DB2CF6A    CRC: OK
Module 00FD    64     2ACE2A64    2ACE2A64    CRC: OK
Module 00C7    1      FFEA124F    FFEA124F    CRC: OK
Module 00EE    2      FFE91228    FFE91228    CRC: OK
Module 0011    1148   226D8BFF    226D8BFF    CRC: OK
Module 0001    24     A75985D8    A75985D8    CRC: OK
Module 3604    16     17E3632A    17E3632A    CRC: OK
Module 00A5    51     FFB81271    FFB81271    CRC: OK
Module 00CA    12     1779BA2E    1779BA2E    CRC: OK
Module 280A    4      8581B1D4    8581B1D4    CRC: OK
Module 00CC    12     22B54591    22B54591    CRC: OK
Module 00B7    7      FFE4125F    FFE4125F    CRC: OK
Module 005C    347    E0FF787F    E0FF787F    CRC: OK
Module 0122    1      899944E8    899944E8    CRC: OK
Module 006D    2      75AAEE1A    75AAEE1A    CRC: OK
Module 4002    1      2461EE67    2461EE67    CRC: OK
Module AC55    1      4AF99CF1    4AF99CF1    CRC: OK
Module 006E    2      399394F6    399394F6    CRC: OK
Module 001F    40     1F27C830    1F27C830    CRC: OK
Module 0053    4      3258AD57    3258AD57    CRC: OK
Module 0052    4      7C1EEB3A    7C1EEB3A    CRC: OK
Module 0051    4      C3174192    C3174192    CRC: OK
Module 0050    4      B97C3DFA    B97C3DFA    CRC: OK
Module 0012    49     6A27D669    6A27D669    CRC: OK
Module 0019    32     F45AF489    F45AF489    CRC: OK
Module 0024    155    5C24F9A3    BCD7AC2D    CRC: OK
Module 0023    155    A6FA61E3    A6FA61E3    CRC: OK
Module 0021    155    8BF5CA16    8BF5CA16    CRC: OK
Module 002A    11     36041B2F    36041B2F    CRC: OK
Module 002F    6      489D881E    489D881E    CRC: OK
Module 001E    22     8F0272F1    8F0272F1    CRC: OK
Module 0015    16     F5B28850    F5B28850    CRC: OK
Module 0014    29     1E1CB864    1E1CB864    CRC: OK
Module 001C    53     052BE2CF    052BE2CF    CRC: OK
Module 0017    63     5C718B73    5C718B73    CRC: OK
Module 0002    5      DBCA86EC    DBCA86EC    CRC: OK
Module 0115    210    C55C5B39    C55C5B39    CRC: OK
Module 0109    513    C26D1149    C26D1149    CRC: OK
Module 0108    37     1C63F103    1C63F103    CRC: OK
Module 0106    2      FFE91210    FFE91210    CRC: OK
Module 0105    2      FFE91211    FFE91211    CRC: OK
Module 0104    1      FFEA1212    FFEA1212    CRC: OK
Module 0103    3      FFE81213    FFE81213    CRC: OK
Module 0102    1      FFEA1214    FFEA1214    CRC: OK
Module 20C0    2000   6F2E2CDB    6F2E2CDB    CRC: OK
Module 20C1    2000   8BB132B3    8BB132B3    CRC: OK
Module 2E08    402    2CE8A60F    2CE8A60F    CRC: OK
Module 00AD    46     850620C8    850620C8    CRC: OK
Module 2000    1900   A7172887    A7172887    CRC: OK
Module 2001    1900   70435691    70435691    CRC: OK
Module 2910    167    4F72FBF1    4F72FBF1    CRC: OK
Module 2821    786    1BBB2BEE    1BBB2BEE    CRC: OK
Module 2907    1218   0D471364    0D471364    CRC: OK
Module 1530    4      6F0D9A5A    6F0D9A5A    CRC: OK
Module 1105    16     6F9ACCBF    6F9ACCBF    CRC: OK
Module 1106    128    6F2ACCBE    6F2ACCBE    CRC: OK
Module 2040    450    DB54281A    DB54281A    CRC: OK
Module 2041    450    58DFE2D8    58DFE2D8    CRC: OK
Module 13F5    26     F0B4A2F2    F0B4A2F2    CRC: OK
Module 00B5    2047   266AEEF2    266AEEF2    CRC: OK
Module 00E0    3200   F6D7996C    F6D7996C    CRC: OK
Module 00E1    3200   B1C8416E    B1C8416E    CRC: OK
Module 2913    167    4B57E42C    4B57E42C    CRC: OK
Module 0066    459    4B6EB73B    4B6EB73B    CRC: OK
Module ADDD    334    D343FD3A    D343FD3A    CRC: OK
Module 3C10    104    01933B89    01933B89    CRC: OK
Module 3C20    104    0195537A    0195537A    CRC: OK
Module 3C11    104    985567F8    985567F8    CRC: OK
Module 3C21    104    5982CD73    5982CD73    CRC: OK
Module 3F03    50     AEC2DE38    AEC2DE38    CRC: OK
Module 00FE    1500   319ED85F    319ED85F    CRC: OK
Module 2B01    43     85A4BD3D    85A4BD3D    CRC: OK
Module 2822    786    97D91988    97D91988    CRC: OK
Module 120F    17     DFF50017    DFF50017    CRC: OK
Module 1213    16     7789B371    7789B371    CRC: OK
Module 2911    167    F5EC3271    F5EC3271    CRC: OK
Module 121F    16     FFDAB16A    FFDAB16A    CRC: OK
Module 1102    16     FFDB0214    FFDB0214    CRC: OK
Module 1800    21     D772092B    D772092B    CRC: OK
Module 1801    21     157C0B59    157C0B59    CRC: OK
Module 1802    21     2F61098C    2F61098C    CRC: OK
Module 1803    21     AF7B0940    AF7B0940    CRC: OK
Module 1804    21     AC7B067E    AC7B067E    CRC: OK
Module 00E8    1047   236FED4C    236FED4C    CRC: OK
Module 00E9    1047   29A7758B    29A7758B    CRC: OK
Module 2914    167    1E869205    1E869205    CRC: OK
Module 2B02    43     8E1DA6ED    8E1DA6ED    CRC: OK
Module 2912    167    8DBC11CA    8DBC11CA    CRC: OK
Module 0131    459    4B6EB670    4B6EB670    CRC: OK
01.53.42
---------------------------- Defect Module -----------------------------
HDD FW INFO:
Family: TRESSELS
SA Cyl: 256
SA SPT: 1689
External ROM: YES
ROM Size: 256
ROM Version: 002500B3
FW Version: 002500B2
Summary FW Ver: 80.00A80-002500B3
Controller FW Rev: 25.B2F
Servo FW Rev: 46.0A
Overlay FW Rev: 25.B3F
DCM Head: U (55)
DCM Media: Z (5A)
Head Count: 2
Head Map: 0,1
PostPosted: August 6th, 2014, 0:28
Could we see MOD 32 and MOD 01?
Could we also see a SMART report and MODs 20 - 29?
Better still, could you upload all your drive's resources?
PostPosted: August 6th, 2014, 2:20
If a mod has good CRC doesn't mean that is OK, we have to see inside it.
Post your drive firmware in this thread so we can see them + SMART report
PostPosted: August 6th, 2014, 4:00
Here is my smart log:
ID  Attribute Description               Threshold   Value   Worst   Data        Status
01  Raw Read Error Rate                 51          198     198     21671       OK
03  Spinup Time                         21          174     173     2291        OK
04  Start/Stop Count                    0           99      99      1091        OK
05  Reallocated Sector Count            140         200     200     0           OK
07  Seek Error Rate                     51          200     200     0           OK
09  Power-On Time Count                 0           97      97      2423        OK
0A  Spinup Retry Count                  51          100     100     0           OK
0B  Calibration Retry Count             0           100     100     0           OK
0C  Power Cycle Count                   0           99      99      1068        OK
B8  End-to-End Error                    97          100     100     0           OK
BB  Reported Uncorrectable Errors       0           1       1       15111       OK
BC  Command Timeout                     0           85      70      1900600     OK
BE  Airflow Temperature                 40          63      56      622592037   OK
C0  Power-Off Retract Count             0           200     200     273         OK
C1  Load/Unload Cycle Count             0           200     200     817         OK
C4  Reallocation Event Count            0           200     200     0           OK
C5  Current Pending Sector Count        0           199     199     203         warning
C6  Offline Uncorrectable Sector Count  0           200     200     3           OK
C7  Ultra ATA CRC Error Rate            0           200     200     10          attention
C8  Write Error Rate                    0           200     200     3           OK
Firmware dump attached.
File comment: Family: TRESSELS
SA Cyl: 256
SA SPT: 1689
External ROM: YES
ROM Size: 256
Servo FW Rev: 46.0A
DCM Head: U (55)
DCM Media: Z (5A)
Head Count: 2
Head Map: 0,1
WDCWD10EZEX-80.00A80.zip [19.46 MiB]
Downloaded 1501 times
PostPosted: August 6th, 2014, 8:27
Ultra ATA CRC Error Rate ----> attention
This means that were error while transfering data from hdd to the motherboard, usually this happens when data cable is bad, or then pcb contacts are durty.
Current Pending Sector Count ----> warning
This means that sectors couldn't be read and even remapped, could be due to bad heads or due to strong sectors damage or due to problem on the pcb (durty contact for example).
Read here:
http://it.wikipedia.org/wiki/Self-Monit ... Technology
Show us a picture of pcb contacts, you need torx T8 screwdriver.
If i'm right pcb contacts are really oxidated and you need to clean them with pencil eraser.
P.S.
mod 32 (re-lo list is bad), you need also to clear it but you can't with sediv demo
PostPosted: August 6th, 2014, 15:38
Unfortunately i have one of those screwdrivers with interchangeable heads and seemed to have misplaced my torx T8 head. I'm afraid my learning experience ends here or until i can find a torx that fits. I thank you guys for all the help, i learnt a lot and it is much appreciated. I can't wait for my next bad drive so i can learn some more. I'll add a T8 torx to my shopping list in the meantime.
PostPosted: August 6th, 2014, 17:14
There is a way using MHDD to clear the relo-list (MOD 32) and write it back to the drive. According to the following thread, MOD 02 needs to be modified, too. That can also be done with an MHDD script.
WD - Fixing the "Slow Issue" manually:
Let me know if you would like to try this method.
PostPosted: August 7th, 2014, 9:55
I would definitely like to give it a shot. Doing things manually is always more fun.
PostPosted: August 7th, 2014, 16:10
I'd like to proceed cautiously, so I have attached a FreeBasic program that I wrote to automate the clearing in MOD 32. I have also attached the resulting BIN file. You could use a hex editor (eg HxD freeware) to compare the cleared MOD against the original, and then satisfy yourself that it conforms to the information presented in the HDD Oracle thread.
wd32clr2.7z [77.27 KiB]
Downloaded 1540 times
wd_32clr.7z [279 Bytes]
Downloaded 1529 times
PostPosted: August 7th, 2014, 18:55
Attached is a routine to modify MOD 02 according to the information in the HDD Oracle thread. I have also attached the modified MOD 02.
02slofix.7z [76.98 KiB]
Downloaded 1616 times
02slofix.7z [1.03 KiB]
Downloaded 1510 times
PostPosted: August 8th, 2014, 4:05
Good Job Frank.
Is valid for all WD drives?
PostPosted: August 8th, 2014, 20:17
I apologize for the untimely reply, it was a busy day for me. I have confirmed mod 32 conforms with the HDD Oracle thread. Offset A5 to end zeroed, looks good.
File comment: Before(left) ; After(right)
However i don't understand how mod 02 is edited. what exactly is happening at offsets 0x0C and 0x0622?
Also, neat little program you have there :)
I would also be glad if someone could explain to me how to properly post images.
Users browsing this forum: No registered users and 48 guests
