 Post subject: Question about bypass micro usb/sat WD my passaport
PostPosted: August 6th, 2014, 16:25
A simple questions.
If i make the usb to sata bypass and the data is encrypted... can i just format the HDD and use normally???
There is some risk to use with the bypass like overheat or something like that??
 Post subject: Re: Question about bypass micro usb/sat WD my passaport
PostPosted: August 6th, 2014, 17:47
AISI, there is no risk, but you may find that the cabling will be subject to interference and interface errors.
PostPosted: August 7th, 2014, 6:29
Hola ddryu!
Para uso comun de los discos, esto no es muy recomendable, ya que la calidad de las soldaduras y los cables no es la misma que de fabrica, y como dice fzabkar que es muy bueno en electronica, "el cableado puede estar sujeto a interferencias electromagneticas"
Al precio de los discos creo que no es una practica recomendable
Hi [b] ddryu [/ b]!
For common use of disks, this is not recommended, since the quality of the ironed points and wires is not the same as from factory, and as [b] fzabkar [/ b] says (He is very good at electronics), "wiring may be subject to electromagnetic interference "
with the actual price about HDD, I think it is not a recommended practice
PostPosted: August 7th, 2014, 6:31
acerca de puentear el adaptador IC SATA-USB, creo que no habrĂ¡ problema en que puedas usar el disco si lo formateas.
About formating drive, i never try it but i thik you will be no problems.
PostPosted: August 7th, 2014, 15:45
Thanks both for the quick answer =)
PostPosted: August 8th, 2014, 3:59
Hola ddryu!
Si lo pruebas comentanos como te ha ido, para referencias futuras.
Hi ddryu!
If you try it let us know how works it, for future reference.
Users browsing this forum: No registered users and 73 guests
