 Post subject: Hitachi HDT721010SLA360 - No life
PostPosted: August 9th, 2014, 7:07
Hi
I have a Hitachi HDT721010SLA360 Disk. When powered on not spinning up and silent.
PC3000 shows all registers red and bsy
Please find the attached pics.
What cud be the likely issue with this drive ?
 Post subject: Re: Hitachi HDT721010SLA360 - No life
PostPosted: August 9th, 2014, 8:18
very likely bad pcb.
My firmware database:
PostPosted: August 9th, 2014, 12:06
Could be bad heads as well...
http://www.rescue-it.se
PostPosted: August 11th, 2014, 5:46
If bad heads will it cause no spin?
PostPosted: August 11th, 2014, 6:12
Ive seen this on SLA models...
PostPosted: August 11th, 2014, 16:05
Isolate pcb and see if it spins. Could be burnt out motor.
PostPosted: August 11th, 2014, 16:07
Sorry, but this makes no sense.
PostPosted: August 12th, 2014, 6:37
I think Bad PCB, you need donnor PCB.
PostPosted: August 12th, 2014, 8:29
It could be bad PCB, sometime it's bad head.
If you have SD SATA TO IDE converter then you can see if 2 LEDs are on or off. If 1 is on, another 1 is off. Then it's PCB.
If both LEDs are on, then it's internal damage.
Isolate PCB from HDA, you can also confirm.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: August 12th, 2014, 15:50
Isolate pcb from hda. Now it makes sense ?
PostPosted: August 12th, 2014, 16:34
By all means, do what you have suggested.
However, from what the other professionals are saying, it would appear that isolating the preamp on a good drive may prevent it from spinning up, presumably because the MCU may need to detect the preamp. Therefore, if they are correct, and if the drive does spin up after isolating the preamp, this would point to a burnt out preamp. If it doesn't spin up, then we wouldn't know whether the motor or preamp were at fault, or whether the fault was somewhere else.
If I were testing for a bad motor or preamp, I would use a multimeter to test the motor windings and the resistance on the preamp's negative supply.
cron
