Post new topic Reply to topic  [ 45 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: WD Black issue
PostPosted: August 11th, 2014, 6:58
Hello. ( thanks Michael i have emailed you)
I received the new donor today , but unfortunately the drive still clicks. and the bios does not see the drive.
so I presume the preamp is damaged and I need to replace the head stack.
I have a dust free environment box, the type you put your arms through and a glass panel to see through.
so I could attempt a repair, if i had the correct parts and tools.
I think I need to find a duplicate working drive and also a special tool to prevent the heads from touching.
It may be worth a try one day.
PostPosted: August 11th, 2014, 7:42
I'm sorry that your hard drive still has other problems.
Yes, very likely the pre-amp is burned because i have found on your original pcb the following issue:
1) SMOOTH chip burned (VCM controller).
2) Shorted D3 (5 volt TVS diode).
3) Open R67
You can't fix pre-amp, anybody can't fix. The only way to recover your data is to send the drive to some DR with clean room so that they can change heads.
I'm sorry :(
If data are really important don't change head stack on your own, let do it to pro.
My firmware database:
PostPosted: August 11th, 2014, 17:26
Thanks Michael for all your awesome help and advice over the past week !!
have a great summer.
PostPosted: August 12th, 2014, 2:20
Hello teerp,
I doon't know from where you are, but I think that yould be the best way to found pro DR near you to recover your data. Otherwise you will spend a lot of money and final result will be, that data will gone and you will have some new knowledge about datarecovery and tools.
Good luck
PostPosted: August 12th, 2014, 6:53
Hi Teerp
Most probably Bad Pream as said yoou Michael. but maybe other problems like media damaged
you need heads stack exchange. no DIY.
i send you a msg.
Users browsing this forum: Google [Bot] and 55 guests
