Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
 Post subject: Re: hard disk size 0 but it spins !
PostPosted: August 14th, 2014, 9:37
hello zio_mangrovia,
where are you located?
PostPosted: August 14th, 2014, 17:07
Why?
Italy
PostPosted: August 15th, 2014, 6:06
Why?
Italy
They as you where are you located, because the best is to contact with local pro if your data es valuable.
PostPosted: August 15th, 2014, 6:11
In Italy you hace forma example:
Michael
memberlist.php?mode=viewprofile&u=21477
Powermax
memberlist.php?mode=viewprofile&u=5285
And others
PostPosted: August 18th, 2014, 18:34
if your mb have 4 sata connectors and your primary drive is on port 1, then connect your damaged drive to port2.
In device manager disable secondary channel.
then in sediv select secondary channel.
check botom links
follow following instruction http://sediv2008.narod.ru/Settings.rar
I found out with Michael help, it's not possible to read module firmware 1 , rom is ok.
suggestions ?
Users browsing this forum: maxisvk, quinkq and 279 guests
