 Post subject: WD2500BEVT-60ZCT1 Resource File needed
PostPosted: August 15th, 2014, 11:22
Hi
I need resource file for WD WD2500BEVT-60ZCT1 Hard Drive.
Firmware: 13.01A13
P/N: 497916-003
Date: 05 FEB 2012
Someone has tried to convert this HDD to work with X-Box and has mess up the firmware. I do have firmware for it but no RES file for SD HD doctor.
my email is: motyr@wp.pl
 Post subject: Re: WD2500BEVT-60ZCT1 Resource File needed
PostPosted: August 15th, 2014, 15:37
I don't understand why you need a RES file, but if HDDHackr was used, then it will have modified MOD 0D and MOD 02. AIUI, MOD 02 is sometimes backed up in MOD 802F or MOD 802E at offset 0x200.
See http://www.users.on.net/~fzabkar/HDD/Hd ... lysis.html
PostPosted: August 15th, 2014, 21:51
The problem is that the drive is no longer recognized by computer and HDDHackr cannot do anything with the drive. I have tried to restore HDD from undo.bin (correct file for my drive) but HDDHackr want first do a backup and this is where it shows error that it cannot access the drive.
I have tried to connect it to HD Doctor WD but the drive is not recognized, it shows "ready" but cannot "load from HDD"
This is why I have asked for RES file.
PostPosted: August 16th, 2014, 10:18
Have you tought to yourself, that there might be another way to use WD doctor to solve this?
Check the manual....
ACELab partner
Users browsing this forum: Google [Bot] and 91 guests
