 Post subject: retrieve firmware from PCB bios
PostPosted: August 15th, 2014, 5:30
Does it exist way to retrieve pcb firmware into WD hard disk to transfer it to donor disk?
I'd like to not unsolder/solder bios chip.
Is there cheap programmer?
Sediv software can do this job?
 Post subject: Re: retrieve firmware from PCB bios
PostPosted: August 15th, 2014, 6:16
Se la pcb non è guasta (e ovviamente nemmeno il chip rom) puoi usare sediv in versione demo per effettuare la copia della rom.
Se la pcb è guasta puoi utilizzare un programmatore eprom economico come il Willem 5.0 in grado di leggere questo tipo di chip rom (ma ti servirà anche l'adattatore sop8 a molletta per agganciarlo fisicamente).
http://www.drivestar.biz/adapter-sop8-s ... 9gs4dlt4g3
P.S.
In base al tipo di guasto sulla pcb potrebbe non essere possibile effettuare il backup della rom direttamente tramite il programmatore, in quel caso l'unico modo sarebbe quello di dissaldare la rom per poi risaldarla su una pcb donatrice.
My firmware database:
PostPosted: August 15th, 2014, 6:51
As michael said you es posible you need a soic reader
PostPosted: August 15th, 2014, 10:47
P.S.
thank you very much!
In italian language it's better :D
I installed and tried trial Sediv, but how I can find info to save ROM from damage pcb by Sediv?
Can you suggest me link to buy both sop8 + Willem programmer please?
PostPosted: August 15th, 2014, 16:16
I sent you a PM.
You can find those on ebay.
I can help you to save rom with sediv if you have teamviewer for remote assistance
http://www.teamviewer.com/it/Index.Aspx
Users browsing this forum: Majestic-12 [Bot] and 65 guests
