 Post subject: Recover data from formatted pendrive 8GB(SAMSUNG K9ABG08U0A)
PostPosted: August 19th, 2014, 4:08
Something broke in my pen drive and it stopped showing as regular drive but instead it showed as 'no media', and there was no way that I could find to access it, so I've decided to format it and then recover the data.
Quick formatting in windows went fine, I used standard settings FAT32, allocation unit size 4096 bytes, and then pen drive started working normally. But the problem is that I tried to recover it with all free programs, and even trials (just to see is it recoverable), but I couldn't find any program who will find even a single file.
My idea is that maybe I used other file system and that makes the problem.
Can anyone help me?
Regards,
Pawel
 Post subject: Re: Recover data from formatted pendrive 8GB(SAMSUNG K9ABG08
PostPosted: August 19th, 2014, 8:39
Bad decisions...
MrRazoR wrote:
I tried to recover it with all free programs, and even trials [...] I couldn't find any program who will find even a single file [...] Can anyone help me?
Depending on the programs you used, if the scan went well and if they didn't find anything, I think your data are lost and nobody can help you.
Lemmy
PostPosted: August 19th, 2014, 8:53
if you use a disk imager such DMDE to take an image/clone of the whole disk, not just any partitions it might find.... and running on the image GetDataBack or r-studio doesn't find any files when told to ignore fat and search for lost files.. then I think you are S.O.L.
You say the drive works, otherwise I may suggest chip off solution, but in this case I think not.
PostPosted: August 24th, 2014, 16:59
I tried those solutions, but resulted in finding nithing but two 12bytes txt files 00.txt and 01.txt, so am I SOL? Or some smart guy specialist with equipement can help me recover something?
Regards,
Pawel
PostPosted: August 24th, 2014, 19:56
doesn't sound good, but did you take the image of the whole disk, or partition? If the whole disk then I would say probably out of luck. If you did a partition I can only suggest retrying with the whole disk. If the Imaging process worked, it is odd not to find more if the format was only a quick format. If it was a full format, then not so odd.
PostPosted: September 8th, 2014, 11:41
Try to look at the content of the Flash using Winhex or R-studio; if you can see data other than 00, FF or both, then there is a chance that some data is still there. Otherwise....
PostPosted: September 8th, 2014, 21:40
Sometimes the controller goes stupid and thinks it is a memory bar or forgets it has NAND attached. If everything else fails, send it to someone that does chip-off recovery, and has a no solution-no fee policy. It wouldn't take me long to see if the data could be recovered or not.
PostPosted: September 9th, 2014, 2:35
Hi MrRazoR!
As HaQue says most pobably your NAND controler had gone.
If you need recover data you need expecializad tools to controler emulation. contact with local pro.
I think in poland you have pros for this work, if not i know somebody on Russia that can help you.
Users browsing this forum: No registered users and 96 guests
