 Post subject: p410i G6 Raid Configuration
PostPosted: August 29th, 2014, 10:29
Anyone know/willing to share the raid parameters for a p410i g6 raid 5?
Will definitely return the favor if able. :)
 Post subject: HP p410i G6 Raid recovery
PostPosted: August 29th, 2014, 23:43
Personally I very rarely remember any RAID configs unless it's something totally exotic.
Check WinHex, there's a preset for HP RAID arrays with delayed parity, it may not fit all xL3** Proliants instantly, particularly pay attention to the stripe size - it may be set to a greater value than necessary (do not recall WH's default and don't have a PC atm).
If it won't work, then either deeper manual inspection is necessary or there's a problem with data, which is also to be solved manually.
 Post subject: Re: p410i G6 Raid Configuration
PostPosted: September 2nd, 2014, 8:26
Thanks for the interest guys. I solved this case before the weekend.
PostPosted: September 3rd, 2014, 5:34
HI JAr
Can you report solution?
thanks
PostPosted: January 9th, 2015, 9:57
Can Anyone know /willing to share the raid parameters for a p410i g6 controller for RAID 5 Configuration. Specially the default offset and strip size.
PostPosted: January 12th, 2015, 15:09
Offset: 088000h
Stripe size: 01000h
Delay: 16
You can find everything this in HP service area located on the drives.
Angel Data Recovery
PostPosted: January 16th, 2015, 9:29
Hello Dr-keiv,
I tried the parameters shared by you for HP Smart array p410i RAID Controller but did not get success in it.
To simplify the matter i tried took new drives connected three drives of same capacity and build the RAID 5 volume with default parameters on the same server.
Now i know the STRIP size, block order/ Rotation. Still i am unable to get proper data out of this experimental volume.
I am missing somewhere offset possible or the PARITY delay and First Parity.
Any suggestion how does one identify these parameters manually.
Thanks for sharing the info.
PostPosted: January 16th, 2015, 10:26
If you have the volume you know everything about, do not build it in the GUI right away, but analyze on a lower level, e.g. with a hex editor you have.
Should you still need an assistance with the client's array afterwards, I'll be glad to help recovering it remotely.
PostPosted: February 18th, 2015, 2:21
Thank You All for your suggestion.
Specially DR-Kiev and Dimitri.
As suggested, i inspected all the elements and was able to successfully recover the data.
A HAPPY CLIENT :D :D
 Post subject: hp p410i G6 data recovery
PostPosted: February 18th, 2015, 4:11
Well, I think it's also worth saying thanks to your client for being patient :)
PostPosted: September 30th, 2022, 21:48
I know this is old ... but this sucks!!! lol.
The only way I can get the configuration of this old ass POS's RAID config ...
is if I buy a product which fan fix the SA of SAS drives. :'(
(And PC3000 doesn't even do SAS SSD under any circumstance according to emails) ...
And this customer? Had multiple configurations which I have to somehow figure out wtf they were.
One is def a RAID-1 thrown in for good measure: Was he mirroring one of the drives from the RAID-5 !?
It'd degraded ... i think. I don't even know if he knows if that drive was part of this 8-drive set! lol
Is it configured as "Right" or "Left" RAID ..?
Holy shit this one's a pita.
PostPosted: October 3rd, 2022, 4:23
Left asymmetric with parity delay. Offset from 1088
Angel Data Recovery
