 Post subject: How does use of a damaged drive affect the firmware?
PostPosted: August 23rd, 2014, 14:49
How does use of a damaged drive (e.g. bad heads) affect the firmware?
For example, will using a drive with a damaged head eventually lead to corrupt firmware as well?
 Post subject: Re: How does use of a damaged drive affect the firmware?
PostPosted: August 25th, 2014, 6:09
Is not recomended to use damaged heads, because can damage media and FW.
PostPosted: September 1st, 2014, 15:50
ok thanks hhddrec.
Does anyone else have anything to say on this?
Does firmware get damaged by using a faulty drive?
PostPosted: September 1st, 2014, 16:23
Yes, it builds up a large defect list and could overflow it to the point that the drive will not start.
http://www.rescue-it.se
PostPosted: September 2nd, 2014, 13:38
Main problem comes from the drives inability to write back critical dynamic firmware modules , (If the firmware resides on a surface with damaged head/s)
PostPosted: September 3rd, 2014, 5:21
smart words here.
Users browsing this forum: No registered users and 299 guests
cron
