Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10EAVS-00D7B1 firmware issue
PostPosted: September 2nd, 2014, 15:25
Changing the head map in ram is not worked.
I think the problem as you said: "Probably a weak head, preventing full translator initialisation"
Thank you pcimage!
PostPosted: September 2nd, 2014, 15:28
saltwater wrote:
1. upload all modules to donor drive
2. start donor drive with patient PCB
3. spin down donor drive and hot swap PCB to patient drive
4. spin up patient drive with it's own PCB
5. let's imaging
These five steps are work, now imaging the drive
Thanks the help for all.
PS: The donor drive is a WD10EACS with the same head map.
It's called a "smart hot swap":
http://www.deepspar.com/blog/Smart-Hot-Swap-Method.html
PostPosted: September 3rd, 2014, 4:40
Thanks fzabkar.
Yes it's a smart hot swap, but i copied only the firmware modules, not the whole SA tracks, because the SA tracks has several bad sectors.
PostPosted: September 3rd, 2014, 5:08
hi Saltwater; very good job.
if all data needed now head stack exchange needed.
PostPosted: September 5th, 2014, 4:23
Okay. After a head stack exchange my case is done with 99,9% success rate.
PostPosted: September 7th, 2014, 17:27
Very good job
Only head exchange needed por hoy swap needed too¿
PostPosted: September 8th, 2014, 16:41
Thanks!
WDR head diagnostics "says" that the heads are ok, thats why i use smart hot swap method, but now i know, the head stack exchange would have been enough for initializing the translator, and imaging.
Users browsing this forum: No registered users and 246 guests
